Blend,Mode and Recirculation
Driver side vents only blow ambient temp. NO cold AC air from it. But passanger side blows icy cold. Which actuator do I replace? And where is it located? Does anyone have a diagram of it? I know there's 2 actuators on the driver side and 1 on the passanger side. Help! Thxs. Also.... if I go to rockauto or others sites.... they show multiple actuators and valley them temp,mode,rec and blend. Becomes so confusing. I have the 2015 Edge 2.0L Titanium trim with dual climate auto control. If anyone can point directly to a link to the proper actuator, that would be amazing
Edited by 1004ron
Keep it to one thread !!
Ahh thanks! The site was acting funny yesterday. Created a double post. Good to see it merged.Ā  Can anyone confirm this is the correct part?
Ā
HVAC Heater Blend Door Actuator Compatible with 2007-2015 Ford Edge Lincoln MKX Left Main Temperature Replaces 7T4Z19E616B 604-239 (Left Main Temperature Actuator) https://a.co/d/aiOeDPD
Ā
And those who did it , was it a hard job?
  • Haha 1
Little update. This morning I noticed it blowing cold air. Do it's become intermittent.Ā  This started 3 days ago. Suspecting it's a failing temp blend door actuator. Also... about a year ago o fo recall doing the MODE actuator due to the vents not wanting to switch to windshield. They were stuck on front amd lower vents only. The mode actuator fixed the issue. But now for about 2 months now I haven't been able to switch to ground vents unless I do the system reset procedure that fixes it but once I play around to move the vents it fails again. Ever since this started happening I hear a click click sound when the car gets turned off. The typical clicking some people get when the hvac is acting up. What are the chances the mode actuator failed only after 1 year? I bought it off Amazon from Dorman.Ā
From the 2015 Edge Workshop Manual...
Ā
Climate Control System - Dual Automatic Temperature Control (DATC) - Component Location
1601943549_ClimateControlSystem-DualAutomaticTemperatureControl(DATC)-ComponentLocation-2015EdgeWorkshopManual.thumb.jpg.ba46e6eb51b6145a71566f1c2cbf60a4.jpg
300232686_ClimateControlSystem-DualAutomaticTemperatureControl(DATC)-ComponentLIST-2015EdgeWorkshopManual.jpg.5cd82b4d07e932e2dd084647c83565a5.jpg
Ā
Air Handling
There are 4 door actuators that control the air flow into the passenger compartment:
  • Air distribution
  • Air inlet
  • Driver side temperature
  • Passenger side temperature
All of the door actuators contain a reversible electric motor and a potentiometer. The potentiometer circuit consists of a 5-volt reference signal connected to one end of a variable resistor, and a signal ground connected to the other. A signal circuit is connected to a contact wiper, which is driven along the variable resistor by the actuator shaft. The signal to theĀ FCIMĀ from the contact wiper indicates the position of the actuator door. TheĀ FCIMĀ powers the actuator motors to move the doors to the desired positions. The desired door positions are calculated by theĀ FCIMĀ based on the set temperature, in-vehicle temperature, ambient air temperature and sunload.
Ā
When an airflow mode, desired driver or passenger temperature, fresh air, or recirculation mode is selected, theĀ FCIMĀ moves the actuator motor in the desired direction.
Ā
TheĀ FCIMĀ sends aĀ PWMĀ signal to the blower motor speed control to regulate the blower speed as necessary. The blower motor speed control provides variable ground feed for the blower motor based on the input from theĀ FCIMĀ . A delay function provides a gradual increase or decrease in blower motor speed under all conditions.
Ā
AUTO
When AUTO is selected:
  • theĀ HVACĀ system operates in a manner to achieve and maintain the temperature set by the operator.
  • the driver and passenger side temperature doors are automatically controlled by theĀ FCIMĀ based on the temperature setting.
  • theĀ A/CĀ compressor is automatically controlled by theĀ PCMĀ from information sent by theĀ FCIMĀ , based on the temperature setting. TheĀ A/CĀ compressor operates as long as the outside temperature is above approximately 0Ā°C (32Ā°F).
  • the blower motor speed is automatically controlled through the blower motor speed control that receives aĀ PWMĀ signal from theĀ FCIMĀ based on the temperature setting, but can be manually overridden.
  • theĀ FCIMĀ controls the air inlet door to recirculate, partially recirculate or open to the fresh air position depending on the in-car temperature and humidity sensor inputs.
OFF
When OFF is selected:
  • the air inlet door closes, preventing outside air and allowing only recirculated air.
  • the blower motor is off.
MAX A/C
When MAX A/C is selected:
  • the recirculated air indicator is illuminated (recirculated air forced on).
  • the footwell vent doors and defrost vent/register doors operate in combination to direct airflow to the instrument panel registers.
  • the temperature doors move to the full cool position. Air temperature can be manually overridden.
  • theĀ A/CĀ button is illuminated.
  • theĀ A/CĀ compressor operates as long as the outside temperature is above approximately 0Ā°C (32Ā°F).
  • the blower motor is commanded to the highest speed. The blower motor speed is adjustable.
PANEL
When PANEL mode is selected:
  • the recirculated air request button is enabled. If the recirculated air request button is selected (indicator on), the air inlet door closes, preventing outside air from entering the passenger compartment. If the recirculated air request button is not selected (indicator off), the air inlet door opens, allowing only outside air into the passenger compartment.
  • blended air temperature is available. Only whenĀ A/CĀ compressor operation has been selected by pressing theĀ A/CĀ button (indicator on) can the airflow temperature be cooled below the outside air temperature.
  • the blower motor is on and the speed is adjustable.
PANEL/FLOOR
When PANEL/FLOOR mode is selected:
  • the air distribution doors operate in combination to direct airflow to the floor duct and the instrument panel registers. A small amount of airflow from the side window demisters and defrost duct is present.
FLOOR
When FLOOR mode is selected:
  • the air distribution doors operate in combination to direct airflow to the floor duct. A small amount of airflow from the defroster duct and side window demisters is present.
FLOOR/DEFROST
When FLOOR/DEFROST mode is selected:
  • the air distribution doors operate in combination to direct airflow to the floor duct, the defroster duct and the side window demisters.
MAX DEFROST
When MAX DEFROST mode is selected:
  • the recirculated air request button is disabled. The air inlet door opens, allowing only outside air into the passenger compartment.
  • the air distribution doors operate in combination to direct airflow to the defroster duct and side window demisters. A small amount of airflow from the floor duct is present.
  • theĀ A/CĀ is turned on in defrost mode. TheĀ A/CĀ compressor operates as long as the outside temperature is above approximately 0Ā°C (32Ā°F).
  • the temperature is set to the highest setting and isĀ notĀ adjustable.
  • the fan is set to the highest speed and isĀ notĀ adjustable.
  • MAX DEFROST can be exited by pressing the AUTO button.
Ā
Climate Control System - Dual Automatic Temperature Control (DATC) - Front Controls Interface Module (FCIM) to Air Flow Door Actuators - Wiring Diagram
1524857778_ClimateControlSystem-FCIMtoAirFlowActuatorsWiringDiagram-2015Edge.thumb.jpg.ff303b2684538b209a90224b8a73a8af.jpg
Ā
Ā
Ā
Climate Control System - Electronic Manual Temperature Control (EMTC) - Component Location
817659260_ClimateControlSystem-ElectronicManualTemperatureControl(EMTC)-ComponentLocation-2015EdgeWorkshopManual.thumb.jpg.b03f6f09d5119c90db01c0f7bb649e42.jpg
234323127_ClimateControlSystem-ElectronicManualTemperatureControl(EMTC)-ComponentLIST-2015EdgeWorkshopManual.jpg.0025f311e82317216513bf1ee5729809.jpg
Ā
Air Handling
There are 3 door actuators that control the air flow into the passenger compartment:
  • Air distribution
  • Air inlet
  • Temperature
Ā
When an airflow mode, desired temperature, fresh air, or recirculation mode is selected, theĀ FCIMĀ moves the actuator motor in the desired direction.
Ā
Ā
OFF
MAX A/C
  • the air inlet door closes allowing only recirculated air.
  • the temperature door moves to the full cool position. Air temperature can be manually overridden.
  • theĀ A/CĀ compressor operates if the outside temperature is above approximately 0Ā°C (32Ā°F).
PANEL
  • blended air temperature is available. The airflow temperature is only cooled below the outside air temperature when theĀ A/CĀ is commanded on.
PANEL/FLOOR
FLOOR
FLOOR/DEFROST
MAX DEFROST
Ā
Climate Control System - Electronic Manual Temperature Control (EMTC) - Front Controls Interface Module (FCIM) to Air Flow Door Actuators - Wiring Diagram
955955129_ClimateControlSystem-MANUAL-FrontControlsInterfaceModule(FCIM)toAirFlowDoorActuatorsWiringDiagram.thumb.jpg.0f96a061008a8eb2f45d5095e185220f.jpg
Ā
Document download links>
Ā
Air Distribution Door Actuator - Removal and Installation - 2015 Edge Workshop Manual.pdf
Gateway Module A (GWM) - Removal and Installation - 2015 Edge Workshop Manual.pdf
Supplemental Restraint System (SRS) Depowering - General Procedures - 2015 Edge Workshop Manual.pdf
Driver Knee Airbag - Removal and Installation - 2015 Edge Workshop Manual.pdf
Supplemental Restraint System (SRS) Repowering - General Procedures - 2015 Edge Workshop Manual.pdf
Ā
Air Inlet Door Actuator - Removal and Installation - 2015 Edge Workshop Manual.pdfĀ
(Requires extensive disassembly of Instrument Panel andĀ Floor ConsoleĀ not described in this document)
Ā
Driver Side Temperature Door Actuator - Removal and Installation - 2015 Edge Workshop Manual.pdf
Brake Pedal and Bracket - Removal and Installation - 2015 Edge Workshop Manual.pdf
Stoplamp Switch - Removal and Installation - 2015 Edge Workshop Manual.pdf
Accelerator Pedal - Removal and Installation - 2015 Edge Workshop Manual.pdf
Ā
Passenger Side Temperature Door Actuator - Removal and Installation - 2015 Edge Workshop Manual.pdf
Ā
Ā
TEMPERATURE DOOR ACTUATOR RH - Connector C2092 Details - 2015 Edge.pdf
FRONT CONTROLS INTERFACE MODULE (FCIM) - Connector C2402A Details - 2015 Edge.pdf
FRONT CONTROLS INTERFACE MODULE (FCIM) - Connector C2402B Details - 2015 Edge.pdf
Front Controls Interface Module (FCIM) - Removal and Installation - 2015 Edge Workshop Manual.pdf
Ā
Ā
FromĀ Climate Control System - Dual Automatic Temperature Control (DATC) - Diagnosis and Testing - 2015 Edge Workshop Manual...
Ā
FCIMĀ -Ā DATCĀ DTCĀ CHART
B1082:13 Right Temperature Damper Motor: Open Circuit ThisĀ DTCĀ sets when the module senses no voltage on the actuator motor circuit when ground is applied to drive the motor, indicating a open circuit. The motor can not move.
Ā
The Temperature Control Is Inoperative Or Does Not Operate Correctly - Passenger Side
Normal Operation and Fault Conditions - Temperature Door Actuator - Passenger side
Ā
During an actuator calibration cycle, the module drives the temperature door until the door reaches both internal stops in theĀ HVACĀ case. If the temperature door is temporarily obstructed or binding during a calibration cycle, the module may interpret this as the actual end of travel for the door. When this condition occurs and the module commands the actuator to its end of travel, the airflow may not be the expected temperature.
Ā
Possible Sources
  • Wiring, terminals or connectors
  • Passenger side temperature door actuator
  • FCIM
PINPOINT TEST J: THE TEMPERATURE CONTROL IS INOPERATIVE OR DOES NOT OPERATE CORRECTLY - PASSENGER SIDE
NOTICE: Use the correct probe adapter(s) when making measurements. Failure to use the correct probe adapter(s) may damage the connector. J1 CHECK THE PASSENGER SIDE TEMPERATURE DOOR ACTUATOR CIRCUITS FOR A SHORT TO VOLTAGE
  • Ignition OFF.
  • DisconnectĀ FCIMĀ C2402A.
  • DisconnectĀ FCIMĀ C2402B.
  • Disconnect Passenger side temperature door actuatorĀ C2092.
  • Ignition ON.
  • Measure:
    Ā
    Positive Lead Measurement / Action Negative Lead
    Ā C2092Ā Pin 1 imagen2.dll?id=E141493_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 2 imagen2.dll?id=E141493_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 3 imagen2.dll?id=E141493_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 4 imagen2.dll?id=E141493_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 6 imagen2.dll?id=E141493_EUR&w=99&t=JPG Ā Ground
    Ā
Is any voltage present?
Ā
Yes REPAIR the circuit.
No GO toĀ J2
Ā  J2 CHECK THE PASSENGER SIDE TEMPERATURE DOOR ACTUATOR CIRCUITS FOR A SHORT TO GROUND
  • Ignition OFF.
  • Measure:
    Ā
    Ā C2092Ā Pin 1 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 2 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 3 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 4 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā Ground
    Ā C2092Ā Pin 6 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā Ground
    Ā
Are the resistances greater than 10,000 ohms?
Ā
Yes GO toĀ J3
No REPAIR the circuit.
Ā  J3 CHECK THE PASSENGER SIDE TEMPERATURE DOOR ACTUATOR CIRCUITS FOR AN OPEN
  • Measure:
    Ā
    Ā C2092Ā Pin 2 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā C2402AĀ Pin 2
    Ā C2092Ā Pin 3 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā C2402AĀ Pin 3
    Ā
    Ā C2092Ā Pin 1 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā C2402BĀ Pin 13
    Ā C2092Ā Pin 4 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā C2402BĀ Pin 18
    Ā C2092Ā Pin 6 imagen2.dll?id=E141499_EUR&w=99&t=JPG Ā C2402BĀ Pin 14
    Ā
Are the resistances less than 3 ohms?
Ā
Yes GO toĀ J4
Ā  J4 CHECK THE PASSENGER SIDE TEMPERATURE DOOR ACTUATOR CIRCUITS FOR A SHORT TOGETHER
Ā
Yes INSTALL a new passenger side temperature door actuator.
REFER to:Ā Passenger Side Temperature Door ActuatorĀ (412-00 Climate Control System - General Information, Removal and Installation).
TEST the system for normal operation. If the concern is still present, GO toĀ J5
Ā  J5 CHECK FOR CORRECT FCIM (FRONT CONTROLS INTERFACE MODULE) OPERATION
  • Ignition OFF.
  • Disconnect and inspect allĀ FCIMĀ connectors.
  • Repair:
    • corrosion (install new connector or terminals ā€“ clean module pins)
    • damaged or bent pins ā€“ install new terminals/pins
    • pushed-out pins ā€“ install new pins as necessary
  • Connect allĀ FCIMĀ connectors. Make sure they seat and latch correctly.
  • Operate the system and determine if the concern is still present.
Is the concern still present?
Ā
Yes CHECKĀ OASISĀ for any applicable Technical Service Bulletins (TSBs). If aĀ TSBĀ exists for this concern, DISCONTINUE this test and FOLLOWĀ TSBĀ instructions. If no Technical Service Bulletins (TSBs) address this concern,
VIN required to access Guided Routine (FCIM)
No The system is operating correctly at this time. The concern may have been caused by a loose or corroded connector. ADDRESS the root cause of any connector or pin issues.
Ā
Ā
Good luck!
Ā
I recently had to change out an actuator in a Taurus because I couldn't get the defrost vents to work.Ā  Major problem in the winter!!!!Ā  I was able to pinpoint which actuator it was by the clicking noise and getting my fingers on it.Ā  Unfortunately it was the upper actuator on the drivers side which was a bitch to get to. I made a little bed out of milk crates and a patio cushion so I could lay down and try to get the 3 screws out.Ā  Took me about 4Ā hours and I only got two screws back in.Ā  Had to go all MacGyver and make a couple extended 1/4" ratchet handles. My wholeĀ body was sore for a few days:)
Hilarious.Ā  I got stiff today from fixing it yesterday! I can't move aswell but fixed it.
Thank you! Good info. What threw me off from that diagram [found it earlier] was the direction it's drawn. Thought the front of the vents were on the bottom of the pic. Turns the bottom is the front [towards hood]. But thxs for the info. I ended up diving in and fixed it. Took both actuators and open to inspect. Both were fine. [MODE and BLEND]. What was the problem was the HVAC flap doors were just very dry and I'm sure dusty on the hinges. I ended up spraying silicon lube and manually spinning the MODE gear to move the flaps to get the silicon moving. After a minute of that... it felt easier to turn. Put it back together and NO MORE clicking. But the warm air issue turned out to be LOW freon. Bought a recharge for 40$ and now it works like new! What a ride!
Edited by 1004ron
No need to quote EVERYTHING
On 8/7/2023 at 9:14 AM, 0LDSCHO0L said:
Same Boat As You. Wife's Edge only blows cold through the passenger side. Hoping you get an answer...
Ā
Turned out to be LOW on freon. 40$ Autozone recharge bottle fixed it. The gadge read on the low side and filled it with 18oz bottle. Now cold air both sides. Apparently very common for duel zone AC systems when they go low on freon. You can try it and recharge. Might get lucky like I did.
