Ownerof2007 Posted August 5, 2023 Report Share Posted August 5, 2023 (edited) Any help would be much appreciated!! I have an overheating issue I can't figure out on 2007 Edge FWD with ~190K mi. The vehicle will run with no issues (temperature neutral) then decide to overheat after an unpredicted period of time. I can sometimes get the engine to cool back down and stay at neutral after running the heater and/or AC. But other times after trying this, it just runs too hot and I have to pull over. I've replaced the thermostat twice and flushed coolant 3 times but issue is not fixed. No engine lights are on with the vehicle running. Any ideas? The heater has not worked for last couple of years so I am wondering if it could be the heater core, but also questioning the temp sensor. I believe both of those are time-consuming replacements. I love this vehicle and have owned it about a decade. Been a reliable family vehicle with looks & design that was ahead of it time in 2007. Thanks in advance for taking the time to read this and give input. Edited August 5, 2023 by Ownerof2007 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 5, 2023 Report Share Posted August 5, 2023 What model/year/engine ? Please add your vehicle details and location to your profile signature - https://www.fordedgeforum.com/settings/signature/ Quote Link to comment Share on other sites More sharing options...
Haz Posted August 5, 2023 Report Share Posted August 5, 2023 (edited) Welcome to the Forum, Ownerof2007 ! Given your long history of ownership, this may be an unnecessary question, but since you didn't mention it among your remedial actions... Have you verified the engine cooling fans are operating consistently? The following Workshop Manual sections may be helpful, especially since you've already replaced several of the items mentioned in the Diagnosis and Testing procedure... Document download links> Engine Cooling - Diagnosis and Testing - 2007 Edge Workshop Manual.pdf Cooling Fan Motor and Shroud - Removal and Installation - 2007 Edge Workshop Manual.pdf Cooling Fan Motor and Shroud - Enhanced Image 1 - 2007 Edge Workshop Manual.pdf Cooling Fan Motor and Shroud - Enhanced Image 2 - 2007 Edge Workshop Manual.pdf Cylinder Head Temperature (CHT) Sensor - Removal and Installation - 2007 Edge Workshop Manual.pdf Cylinder Head Temperature (CHT) Sensor - Enhanced Image - 2007 Edge Workshop Manual.pdf Cylinder Head Temperature (CHT) Sensor - Connector C107 Details and Photo - 2007 Edge.pdf Cylinder Head Temperature (CHT) Sensor - Connector C107 Location - 2007 Edge.pdf Lower Intake Manifold - In-Vehicle Removal and Installation - 2007 Edge Workshop Manual.pdf Lower Intake Manifold - Enhanced Illustration - 2007 Edge Workshop Manual.pdf Good luck! Edited August 5, 2023 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Ownerof2007 Posted August 5, 2023 Author Report Share Posted August 5, 2023 Thank you much for the response and download links. I had not seen these files before and will read through them. The cooling fans seem to be operating consistently. Also, there is no sign of coolant leaks from the system inside or outside the vehicle -- That said, pressure will build up high with bubbling in the reservoir when overheating. In terms of a potential temperature sensor issue, it seems like the check engine light would come on with bad temperature sensor, but maybe I am wrong on that. Thank you again. Quote Link to comment Share on other sites More sharing options...
Haz Posted August 5, 2023 Report Share Posted August 5, 2023 Adding these, then, for your future reference... Document download links> Cooling Fans Wiring Diagram - Without Trailer Tow - 2007 Edge.pdf Cooling Fans Wiring Diagram - With Trailer Tow - 2007 Edge.pdf COOLING FAN MODULE - Connector C1554 Details and Photo - 2007 Edge.pdf COOLING FAN MODULE - Connector C1554 Location - 2007 Edge.pdf Good luck! 1 Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted August 6, 2023 Report Share Posted August 6, 2023 (edited) A possible cause is the RadiatorFans ControlModule, mounted on UpperLeft corner of FanCowling; it's a NotoriousFailureItem, commonly stops responding to Computers FanSpeed signal resulting in engine overheating when idling or in Stop+GoTraffic. Replace with new MotorCraft OEM part only; aftermarket offbrand replacements are often not fully compatible or fail quickly. Edited August 6, 2023 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
Ownerof2007 Posted August 6, 2023 Author Report Share Posted August 6, 2023 (edited) Message deleted Edited August 6, 2023 by Ownerof2007 Quote Link to comment Share on other sites More sharing options...
KasonM Posted June 13 Report Share Posted June 13 Hello, I have started having the same issue. Vehicle has 220k miles, heater hasn't worked in 5+ years, and I recently started having the over heating issue. Were you ever able to find out the cause? Quote Link to comment Share on other sites More sharing options...
