Installation of a seat in EDGE SEL from TITANIUM
Yurez
  • Yurez changed the title to Installation of a seat in EDGE SEL from TITANIUM
Be certain to disconnect the battery. I'm in the process of changing out a 10-way seat switch (one function is touchy). One would expect to remove the old switch, unplug it, then install the new one.
Surprisingly, the service manual  requires the SRS to be disabled before the switch is removed. Then the engine be turned to on to verify the warning light is on, the off and the switch can then be removed. Don't know how the seat restraint system is wired to the seat switch, but .....
  • Thanks 1
18 hours ago, Haz said:
Я предоставил вам внешнюю ссылку для загрузки запрошенной информации о сиденьях с климат-контролем Edge 2018 года через систему сообщений форума из-за ограничений размера файла форума.
Удачи!
thanks for the diagrams. Do you have schematics from the newer EDGE may 2019. I have two control units under the driver's seat and under the passenger seat.
Heated Seat and Climate Controlled Seat wiring & connectors are identical for 2018 Edge and 2019 Edge.
The driver's seat component would be the Driver Front Seat Module (DSM)...
Document download links>
Driver Front Seat Module (DSM) - Removal and Installation - 2019 Edge Workshop Manual.pdf
Driver Front Seat Module (DSM) - Location - 2019 Edge.pdf
For the passenger seat component, look for a part number on it and web-search the part number to identify that component.
For additional clarification, I suggest you consult your local Ford dealership's Parts & Service personnel.
I've supplied you all available resources on this topic.
Good luck!
Information about the Front Seat Climate Control Module (SCME), shown in your above photo, was contained in the recently shared document collection, including:
Climate Controlled Seats - Wiring Diagram 2 - 2018 Edge.pdf - showing SCME in relation to the Left Hand/Driver's seat...
1344217922_ClimateControlledSeats-WiringDiagram2-2018Edge.thumb.jpg.56d6d29d6a6f287e4a34d01fd42ce215.jpg
Climate Controlled Seats - Wiring Diagram 3 - 2018 Edge.pdf - showing SCME in relation to the Right Hand/Passenger's seat...
1910540221_ClimateControlledSeats-WiringDiagram3-2018Edge.thumb.jpg.90c140c9007ea6544423fd51f9ee446a.jpg
FRONT SEAT CLIMATE CONTROL MODULE [SCME] -Connectors C3265A-C3265B-C3265C Location - 2018 Edge.pdf - showing all SCME connectors' relative location...
377542903_FRONTSEATCLIMATECONTROLMODULESCME-ConnectorsC3265A-C3265B-C3265CLocation-2018Edge.thumb.jpg.9a425b367f05d0d032c4b02109e12a6e.jpg
The following documents provide Driver's Seat Module (DSM) connector details on SCME circuits affecting Driver's seat climate control components...
DRIVER SEAT MODULE (DSM) - Connector C341D Details - 2018 Edge.pdf
DRIVER SEAT MODULE (DSM) - Connector C341E Details - 2018 Edge.pdf
DRIVER SEAT MODULE (DSM) - Connectors C341D & C341E Location - 2018 Edge.pdf
Good luck!
Edited by Haz
Always hopeful that visualizations are better than a thousand Google-translated words...
Driver Seat Module (DSM) - Beneath Driver Seat
318133489_DriverSeatModule(DSM)Illustration-BeneathDriverSeat.thumb.jpg.69c0e5e3a9ad74b35dd35bb50791bdac.jpg
Front Seat Climate Control Module (SCME) - Beneath Passenger Seat
44323963_FrontSeatClimateControlModule(SCME)-BeneathPassengerSeat.thumb.jpg.3f4597e10356c5fc64990c6501b8e0ca.jpg
Documents relating to seat-to-seat "adapter cable", as you describe it...
Front Driver Seat - Connector C311 Details - 2018 Edge.pdf
Front Driver Seat - Connector C311 Seat View Location - 2018 Edge.pdf
Front Driver Seat - Connector C311 Harness View Location - 2018 Edge.pdf
Front Passenger Seat - Connector C312 Details - 2018 Edge.pdf
Front Passenger Seat - Connector C312 Location - 2018 Edge.pdf
While Titanium-owning Forum members may offer their own hands-on Climate Controlled Seating insights, I am moving on to research other Forum member questions.
Once again, speaking directly with Parts & Service personnel at your local Ford dealer will eliminate your need for Google Translate.
Good luck!
  • Thanks 1
thanks a lot for your patience and help. but I still do not see the connection diagrams for DSM and SCME blocks on the general diagrams. there is no wiring diagram for the seat controls. thanks again for your help.  how power is connected to the blocks and the data bus.
To accomplish your goal of installing the seats and making them fully functional:
Buy an Edge Wiring Book in your native language.
English language wiring diagrams and connector circuit details are obviously not working...
From the document collection you received...
Climate Controlled Seats - Wiring Diagram 1 - 2018 Edge.pdf, with Labels added
1611063876_ClimateControlledSeats-WiringDiagram1-2018EdgeHIGHLIGHTED.thumb.jpg.d5162dcb8cd4cd44ccb6f9e37e5e6652.jpg
Good luck!
  • Thanks 1
