Misssk Posted July 26, 2023 Report Share Posted July 26, 2023 Changed spark plugs and coils but now getting this error. Any ideas? Engine light is on and flashing. Car has these 4 codes popping up: p0206 a injector circuit/ open cylinder 6 P0306 cylinder 6 misfire detected P0113 intake air temperature sensor 1 circuit high input P0206 injector circuit /open cylinder 6 Quote Link to comment Share on other sites More sharing options...
Misssk Posted July 26, 2023 Author Report Share Posted July 26, 2023 (edited) I should add I have a 2008 ford edge. The car is shaking when I come to a stop or idling. It feels like it’s about to run out of gas. Edited July 26, 2023 by Misssk Quote Link to comment Share on other sites More sharing options...
dabangsta Posted July 26, 2023 Report Share Posted July 26, 2023 I guess you are lucky in that cylinder 6 is the one on the drivers front of the 3.5. It seems like the injector on that cylinder got unplugged, or not plugged back in. The IAT is on the big air inlet tube from the air filter housing, check that it is plugged it also. 1 Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted July 26, 2023 Report Share Posted July 26, 2023 (edited) On 7/26/2023 at 1:06 AM, Misssk said: ...Changed spark plugs and coils...now getting this error...Engine light is on and flashing...4 codes p0206 a injector circuit/ open cylinder 6 P0306 cylinder 6 misfire detected P0113 intake air temperature sensor 1 circuit high input P0206 injector circuit /open cylinder 6 Expand Yep, take a close patient look at your electrical connections; suspect while working on SparkPlugs, harness sockets+plugs got disturbed or forgot to reconnect FuelInjector#6 (cylinder on the front left of the engine) & MassAirFlow\MAFSensor (mounted in AirDuct between the AirFilterBox & ThrottleBody). MAFSensor has a red sliding latch on the underside of the harness socket, easy to reach, just need to know its there: * pull the red latch out to unlock before disconnecting * push the red latch in to relock after re-connecting Fortunately do NOT need to remove UpperIntakeManifold to get at Injector6 harness connection; also easy to reach on top front left of engine V. Edited July 26, 2023 by DILLARD000 Quote Link to comment Share on other sites More sharing options...
