Low idle/stalls with ac on
2007 Edge SEL
When I'm idling with the a/c on, the RPM occasionally dips down really low and will sometimes stall. It runs fine as long as I'm driving, it's only when the car is stopped. If it does stall, I can start it right back up.
I cleaned the throttle body about a year ago (it wasn't even really dirty but I did it anyway) when I replaced the spark plugs. Any ideas on what could be causing the low idle/stall only with the ac?
3 hours ago, Ctakacs9 said:
2007 Edge SEL
...idling with the a/c on...RPM occasionally dips down...sometimes stall
...fine as long as I'm driving...only when the car is stopped
...If it does stall, I can start it right back up
Sounds suspiciously like same problem I had a couple of years ago on a 2008 Edge SELAWD.
With AC on, engin RPMs would randomly dip momentarily or engin may fully stall when at a Stop Sign\Light, then engin would start again fine
Was not getting any OBD2 TroubleCodes at all, so it was a matter of replacing parts 1 at a time until I found something that helped.
Turned out to be the damned Radiator FanControlModule was randomly shorting out the fan speed signal wire from the PCM\Computer,
causing the PCM to die momentarily;  tried several cheaper aftermarket FCMs (Gates, Dorman...), found them not fully compatible with PCM,
so recommend only using OEM Ford part MotorCraft# 7t43-8c607-ag \ 7t43-8c609-ab \ 7t4z-8b658-a;
this is the FCM for the 2007~2010 Edge without a TowRated Radiator package.
Be ware the local parts house (Oreilly, Advanced, ...) & Amazon\Ebay will try to sell you an aftermarket offbrand version;
there is confusion\misinformation amongst both manufacturers+vendors on compatibility of this part.
FCM is mounted on upper left corner of RadiatorFanCowling, plugged into VehcileHarness & FanHarness.
2008.Ford_Cool.RFan_Elec.VFCM_Ford.7t4z-8b658-a.GIF.f381dc439f2ac51ddd64a113a5d8569c.GIF
Edited by DILLARD000
13 hours ago, Ctakacs9 said:
Awesome - thanks for the reply. Was it easy to replace?
Yep, about 30minutes, easy to replace:
* Unplug MAFSensor on AirDuct
* Remove top+bottom of AirFilterBox with AirDuct+MAFSensor to get it out of the way
* Unplug VehicleHarness side of FanControlModule
* Unplug FanHarness side of FanControlModule
* Install new FCM & re-install above items
Basic test of new FCM:
* Start Engin cold, idling with AC off: RadiatorFans should be off
* Switch AC on to minimum cooling, 1st position left from center, temp control on cold: RadiatorFans should come on 25%Speed or faster
Full test of new FCM can be done with ForScan on a Windows Laptop & an OBD2~USB module like the OBDLink#EX.
Video on replacing the FCM, though recommend a MotorCraft part, not Gates:
  • 4 weeks later...
  • 7 months later...
