Jasizzle Posted July 11, 2023 Report Share Posted July 11, 2023 I’ve been having this issue now with my 2017 Edge Se that every time I fill it with fuel at the gas station, it won’t start up right away. Then when it does, it stutters a bit. CEL is on and code says fuel vacuum leak. Have taken to 2 mechanics and they can not find any leak. One even changed out the fuel pump but still having the issue. Any suggestions?? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted July 11, 2023 Report Share Posted July 11, 2023 What is the actual code that is set? I would think this is related to the purge valve or evap system. I wouldn't expect the low pressure in tank fuel pump to be in the list of things to resolve whatever the code that is setting the CEL on. Quote Link to comment Share on other sites More sharing options...
