Sluggish and Whooshing sound -Turbo underboost
I recently bought a 2015 ford edge turbo boost.  It has 88k miles on it when I bought it. I have had it about a month and now when I accelerate it is sluggish and I can hear a whooshing sound. I went by O'Reilly's auto parts and they did a test. I was told that it read Turbo boost underboost and I had to take it to a mechanic or the dealership.  I have researched this problem. Anyone have any ideas of something I could do to help this? any thoughts on what is causing it?
TIA
  • 1004ron changed the title to Sluggish and Whooshing sound -Turbo underboost
Sounds like one of your inlet ducts blew off.
This happened to a few people with Explorer Ecoboosts.
Hose clamps were not tight enough to hold the pressure and blow off.
Simple fix once you find the one that's off.
Loosen clamp, push hose back on, tighten clamp....and then check all others to make sure they are seated and tight.
