2017 edge, intermittent AC on driver side
have a 2017 ford edge.
I can tell the actuator works as i removed it to see if the motor moves when changing from hot to cold in the climate control and it does.
also tried resetting the whole system through the infotainment.
but getting cold air out of the drivers side seems to be an issue. if it's been going for a while sometimes cooler air will come out of the drivers side eventually.. but it's never as cold as the passenger side.
I can't figure out what to do next to fix this.
hot air is no problem, it's just AC/cold air that's the problem.
  • 2 months later...
