dnx8120 - now sub not working?
Hey guys,
I just installed a Kenwood DNX8120 into my 2007 Ford Edge. I bought a wiring harness for the unit and plugged it into the factory wiring harness. Everything works fine except I am getting no output to the factory subwoofer. Any ideas?
Thank you,
Kevin
First, I am assuming the wiring is at least similar if not the same as my 2008 Edge (SEL+ w/ factory sub). There are three separate plugs containing the wiring for the stereo. The subwoofer wiring is in the smallest of the three plugs (has 8 connection terminals, w/ 4 used for sub, and 4 unused).
Not knowing any detail about your new head unit or wiring harness, I could only guess what could be wrong, but perhaps this will help you locate the problem.
