17 Sport - Bilstein B6 Struts with H&R Springs
Does anyone have a video or pictures that show how to assemble B6 struts with H&R springs? I think I ordered everything I needed but I can't make things fit together how I would expect them to. I found the link below but it's H&R Springs on stock struts. I can't find anything that lists the other parts that are needed to complete a strut. I have the Haynes Manual and it shows stock struts but it still seems like something is missing. Below is what I have.
https://drive.google.com/file/d/1wQ3WRD6zvzHaAbxE3hCZpyKIwbBI3-Gs/view
Thank you! That is very helpful. I ordered everything suggested/available from Tire Rack/RockAuto hoping I could assembly the new struts before I take everything apart but it looks like I'll reuse some rubber seats and other small items from the stock set up.
Moving to the rear. I found the following on rear subframe replacement as I've read dropping the subframe makes rear spring replacement easier. I don't need to completely remove the subframe so the workshop manual section has a lot of extra steps. Do I just need to remove the shocks, put a jack under the diff and mark and remove the 4 bolts from the first part of the workshop manual, and lower it slightly to pull out the springs?
  • 1 year later...
  On 9/17/2024 at 2:13 AM, Haz said:
Expand
Thanks for you reply! Do you recommend jacking up one quarter or the car at a time, or putting the whole front on jack stands, then the rear. Or even the entire car all together?
Ford's advice -- and cautions -- about vehicle jacking & lifting from the Edge Workshop Manual are attached below as a PDF document...
Forum Member Emeritus  @macbwt provides this guidance on his MACTFORDEDGE YouTube channel...
Good luck and work safely!
Jacking and Lifting - Overview - 2022-2024 Edge Workshop Manual.pdfFetching info...
  • 6 months later...
Bringing this thread back up. I love the lowered look but the ride is kind of annoying. I know it will be different than stock but I have a noise that, if resolved, I can live with everything else. Whenever I'm on a rough road or go over speed bumps, there is a clunk in the rear end. It sounds like when my old car had broken sway bar end links in the front end but this noise is in the back. I replaced the rear sway bar end links when I installed the springs and new shocks. I've jacked it up and checked bolts and looked for marks that show something is hitting something and I haven't found anything. Has anyone else had this? How do I fix it?
