bscott94 Posted May 17, 2023 Report Share Posted May 17, 2023 Does anyone have a video or pictures that show how to assemble B6 struts with H&R springs? I think I ordered everything I needed but I can't make things fit together how I would expect them to. I found the link below but it's H&R Springs on stock struts. I can't find anything that lists the other parts that are needed to complete a strut. I have the Haynes Manual and it shows stock struts but it still seems like something is missing. Below is what I have. https://drive.google.com/file/d/1wQ3WRD6zvzHaAbxE3hCZpyKIwbBI3-Gs/view Quote Link to comment Share on other sites More sharing options...
bscott94 Posted May 17, 2023 Author Report Share Posted May 17, 2023 @Haz, can you share the strut info from the workshop manual? Would that be different than the Haynes manual? I know it won't be the exact same as the Bilstein strut by hopefully it's the same components. Quote Link to comment Share on other sites More sharing options...
Haz Posted May 17, 2023 Report Share Posted May 17, 2023 Document download links> Windshield Wiper Pivot Arm - Removal and Installation - 2017 Edge Workshop Manual.pdf Cowl Panel Grille - Removal and Installation - 2017 Edge Workshop Manual.pdf Cowl Panel - Removal and Installation - 2017 Edge Workshop Manual.pdf Front Strut and Spring Assembly - Removal and Installation - 2017 Edge Workshop Manual.pdf Front Stabilizer Bar Link - Removal and Installation - 2017 Edge Workshop Manual.pdf Front Strut and Spring Assembly - Disassembly and Assembly - 2017 Edge Workshop Manual.pdf Perhaps the drag/zoom strut-spring assembly illustration and the related-parts detail tab on this FordParts page can be helpful toward assessing the needed parts... Good luck! 1 Quote Link to comment Share on other sites More sharing options...
bscott94 Posted May 18, 2023 Author Report Share Posted May 18, 2023 Thank you! That is very helpful. I ordered everything suggested/available from Tire Rack/RockAuto hoping I could assembly the new struts before I take everything apart but it looks like I'll reuse some rubber seats and other small items from the stock set up. Quote Link to comment Share on other sites More sharing options...
bscott94 Posted May 18, 2023 Author Report Share Posted May 18, 2023 Moving to the rear. I found the following on rear subframe replacement as I've read dropping the subframe makes rear spring replacement easier. I don't need to completely remove the subframe so the workshop manual section has a lot of extra steps. Do I just need to remove the shocks, put a jack under the diff and mark and remove the 4 bolts from the first part of the workshop manual, and lower it slightly to pull out the springs? Quote Link to comment Share on other sites More sharing options...
Haz Posted May 18, 2023 Report Share Posted May 18, 2023 Document download links> Lower Arm - Removal and Installation - 2017 Edge Workshop Manual.pdf Spring - Removal and Installation - 2017 Edge Workshop Manual.pdf Good luck! 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted May 25, 2023 Report Share Posted May 25, 2023 I there any way to do this without a spring compressor? Quote Link to comment Share on other sites More sharing options...
bscott94 Posted May 30, 2023 Author Report Share Posted May 30, 2023 On 5/25/2023 at 11:41 AM, johnmarkp said: I there any way to do this without a spring compressor? I wouldn't try. I got a spring compressor kit from Harbor Freight for $35 and it worked perfectly. 1 Quote Link to comment Share on other sites More sharing options...
johnmarkp Posted May 31, 2023 Report Share Posted May 31, 2023 Good news about the Harbor Freight option. Quote Link to comment Share on other sites More sharing options...
CaspaST Posted September 16, 2024 Report Share Posted September 16, 2024 @Haz do you have the workshop info on a 2023 edge st? Or is it all the same? I’m doing springs shocks and stunts tomorrow morning and haven’t found the best diy yet. Quote Link to comment Share on other sites More sharing options...
Haz Posted September 17, 2024 Report Share Posted September 17, 2024 (edited) Welcome to the Forum @CaspaST! Per your request... Cowl Panel - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Cowl Panel Grille - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Windshield Wiper Pivot Arm - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Front Strut and Spring Assembly - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Front Stabilizer Bar Link - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Front Strut and Spring Assembly - Disassembly and Assembly - 2022-2024 Edge Workshop Manual.pdf Lower Arm - Removal and Installation - 2017 Edge Workshop Manual.pdf Edited September 17, 2024 by Haz Quote Link to comment Share on other sites More sharing options...
Haz Posted September 17, 2024 Report Share Posted September 17, 2024 Additional... Good luck! Lower Arm, Rear Suspension - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Spring, Rear Suspension - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf Quote Link to comment Share on other sites More sharing options...
CaspaST Posted September 17, 2024 Report Share Posted September 17, 2024 1 hour ago, Haz said: Additional... Good luck! Lower Arm, Rear Suspension - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf 1.88 MB · 1 download Spring, Rear Suspension - Removal and Installation - 2022-2024 Edge Workshop Manual.pdf 440.48 kB · 1 download Thanks for you reply! Do you recommend jacking up one quarter or the car at a time, or putting the whole front on jack stands, then the rear. Or even the entire car all together? Quote Link to comment Share on other sites More sharing options...
Haz Posted September 17, 2024 Report Share Posted September 17, 2024 Ford's advice -- and cautions -- about vehicle jacking & lifting from the Edge Workshop Manual are attached below as a PDF document... Forum Member Emeritus @macbwt provides this guidance on his MACTFORDEDGE YouTube channel... How to safely Jack up the front of a Ford Edge and where to place jack stands Safe lift of the rear of a Ford Edge DIY Jack and Jack stand placement Good luck and work safely! Jacking and Lifting - Overview - 2022-2024 Edge Workshop Manual.pdf 1 Quote Link to comment Share on other sites More sharing options...
CaspaST Posted September 17, 2024 Report Share Posted September 17, 2024 I’m confused on my rear bill V6 if I’m supposed to reuse my bump stops? Also once mounted to the top mounting hat, it seems to knock my boots down exposing the rod Quote Link to comment Share on other sites More sharing options...
