CMOS Posted May 16, 2023 Report Share Posted May 16, 2023 I'm currently having a fast turn signal on the right hand side turn signal on my 2011 edge limited. This is due to splice connectors for an LED conversion and a running light mod I did about a decade back. As of now the daytime running light on the turn signal bulb works but the turn signal itself is completely out due to the wire being nearly cut. Does someone know which wire is power for the DRL and which is for the trunk signal. I've attached a picture of my mess below. Thanks! Quote Link to comment Share on other sites More sharing options...
Haz Posted May 16, 2023 Report Share Posted May 16, 2023 Requested 2011 Edge wiring diagram... Document download links> Headlamps, Side Marker LEDs, Park-Turn Lamps, Auxiliary Park Lamps - Wiring Diagram - 2011 Edge.pdf HEADLAMP, SIDE MARKER LEDs, LEFT - Connector C1021A Details - 2011 Edge.pdf HEADLAMP, SIDE MARKER LEDs, RIGHT - Connector C1041A Details - 2011 Edge.pdf PARK-TURN LAMP, LEFT FRONT - Connector C1023 Details - 2011 Edge.pdf PARK-TURN LAMP, RIGHT FRONT - Connector C1043 Details - 2011 Edge.pdf AUXILIARY PARK LAMP, LEFT FRONT - Connector C1445 Details - 2011 Edge.pdf AUXILIARY PARK LAMP, RIGHT FRONT - Connector C1446 Details - 2011 Edge.pdf Good luck! Quote Link to comment Share on other sites More sharing options...
