petespatio Posted April 25, 2023 Report Share Posted April 25, 2023 I have a problem with the drivers side front door won't open any of the windows. The passenger front door can open/close the window. Additionally the power sunroof is not working either. I read about the pin issue within the front drivers door/chassis connector and there does seem to be an issue for when i push on the wires the passenger window control will intermittently work. I found these schematics for the power windows and sunroof. Can you think of a scenario where the front drivers side door connect could be effecting the sunroof? Thanks for any help in advance! bb6e8bf1-3c1b-4726-9b87-ed339c58dacf_eee1.pdf f03efd88-348c-46df-b94d-23f77d16b500_eee.pdf dff28163-8233-4437-91de-5cbab20f4dce_Sunroof___Moonroof__Diagrams__Electrical.pdf Quote Link to comment Share on other sites More sharing options...
burkely001 Posted May 11, 2023 Report Share Posted May 11, 2023 On 4/25/2023 at 5:18 PM, petespatio said: I have a problem with the drivers side front door won't open any of the windows. The passenger front door can open/close the window. Additionally the power sunroof is not working either. I read about the pin issue within the front drivers door/chassis connector and there does seem to be an issue for when i push on the wires the passenger window control will intermittently work. I found these schematics for the power windows and sunroof. Can you think of a scenario where the front drivers side door connect could be effecting the sunroof? Thanks for any help in advance! bb6e8bf1-3c1b-4726-9b87-ed339c58dacf_eee1.pdf f03efd88-348c-46df-b94d-23f77d16b500_eee.pdf dff28163-8233-4437-91de-5cbab20f4dce_Sunroof___Moonroof__Diagrams__Electrical.pdf Hey there, I am currently dealing with this same issue, among other electrical problems, on my 2013 SEL with just a smidge over 100,000 km's. Were you ever able to find any sort of concrete answers on this? I've found that so many folks out there and just for the sake of making a youtube video have come up with random ideas. Mind you, some are much more sensible then others, but it's hard to get a grasp on what will actually work. In addition to the power windows issue, which is now becoming a bit of problem now that the temperature is warming up here in northern Ontario, Canada I'm also dealing with the door ajar issue. This one is quite odd though, because as soon as the fall came with the cool weather last season, I rarely if ever had a door ajar issue. The minute we had a warm stretch, it's not but door ajar issues.. So I'm really just curious as to the direction folks who have recently encountered these electrical issues have gone with it.. I wish I had some advice/pointers to give, but unfortunately, I'm just now looking into the issue. All the best and cheers! Quote Link to comment Share on other sites More sharing options...
MichaelStephens Posted November 8, 2023 Report Share Posted November 8, 2023 I have a 2014 edge, same issue. I finally took drivers door apart and the wire harness to the door has a large glue wire where the pin breaks inside the plug on the door side into the door frame. My boss, at auto shop, took it apart and soldered and then glue sticked over the affected pin, relieved the pulling pressure where it is anchored below the door panel and it fixed the problem. The problem occurred at roughly 165k and i suffered with it 2 yrs and fixedvit at 185 k 1 Quote Link to comment Share on other sites More sharing options...
petespatio Posted November 8, 2023 Author Report Share Posted November 8, 2023 Good to know. I ended up just replacing the door harness. Cost was about $220 Quote Link to comment Share on other sites More sharing options...
