2018 SEL Ecoboost 2.0L - DTC 1015
JBFIGS
After taking my 2018 Edge to service after check engine light,   got Code DTC 1015  related to the wastegate valve in the Turbo Charger.   Would entire turbocharger need replacement, or is this repairable.   If need to replace,   would   replacement Turbochager like Cardone or Rotomaster do the trick?  Or is it recommended to use OEM FoMoCo  Turbocharger?
