Phil09MKX Posted January 11, 2009 Report Share Posted January 11, 2009 (edited) I have a 2008 MKX, does anybody have a problem with the idle after warm up when sitting at a traffic light I feel vibrations in the steering wheel, very annoying. RPM checked by the dealer is 600, they ran all the checks & found nothing wrong. If I feather it up to 700-750 RPM it goes away. The dealer said they can not up the idle that is all set by the computer. I went to the dealer the other & test drove a 2009 model no problem & the idle was 750 on the tach. Please advise if any body has had a similar problem or any fix to my problem. Edited January 11, 2009 by Phil09MKX Quote Link to comment Share on other sites More sharing options...
nacraman Posted January 13, 2009 Report Share Posted January 13, 2009 I have a 2008 MKX, does anybody have a problem with the idle after warm up when sitting at a traffic light I feel vibrations in the steering wheel, very annoying. RPM checked by the dealer is 600, they ran all the checks & found nothing wrong. If I feather it up to 700-750 RPM it goes away. The dealer said they can not up the idle that is all set by the computer. I went to the dealer the other & test drove a 2009 model no problem & the idle was 750 on the tach. Please advise if any body has had a similar problem or any fix to my problem. I have an 09 Edge and I also get a slight vibration in the steering wheel at idle. It is slight but I find myself taking my hands off the steering wheel at lights, so maybe it isn't so slight. It seriously bugs me. Quote Link to comment Share on other sites More sharing options...
Black and White Posted January 16, 2009 Report Share Posted January 16, 2009 Yep, I have an 08 Edge Ltd and I get the same annoying vibration at idle. If Ford ever wants to be considered as good as the Japanese then things like this need to be dealt with. Quote Link to comment Share on other sites More sharing options...
Phil09MKX Posted January 17, 2009 Author Report Share Posted January 17, 2009 Yep, I have an 08 Edge Ltd and I get the same annoying vibration at idle. If Ford ever wants to be considered as good as the Japanese then things like this need to be dealt with. Thank you for the reply. I agree with you, Kind of turns you off on buying American cars. Quote Link to comment Share on other sites More sharing options...
Phil09MKX Posted January 17, 2009 Author Report Share Posted January 17, 2009 I have an 09 Edge and I also get a slight vibration in the steering wheel at idle. It is slight but I find myself taking my hands off the steering wheel at lights, so maybe it isn't so slight. It seriously bugs me. It's funny you said that you take your hands off the wheel at traffic lights cause that is exactly what I do. If you edge your RPM up a little does the vibration go away? Quote Link to comment Share on other sites More sharing options...
akirby Posted January 18, 2009 Report Share Posted January 18, 2009 Yep, I have an 08 Edge Ltd and I get the same annoying vibration at idle. If Ford ever wants to be considered as good as the Japanese then things like this need to be dealt with. I have an 08 Edge with no such vibration (and I'm sensitive to it from previous vehicles). Mine is FWD. Quote Link to comment Share on other sites More sharing options...
