TSB 23-2356 - 2019-2023 Edge/Nautilus - 2.7L EcoBoost - Cold Start Ticking/Tapping Or Rattle Type Noise
Haz
Document download link>
TSB 23-2049 - 2019-2023 Edge-Nautilus - 2.7L EcoBoost - Cold Start Ticking-Tapping Or Rattle Type Noise.pdf
TECHNICAL SERVICE BULLETIN
23-2049
28 March 2023
This bulletin supersedes 22-2376.
Model:
Ford
2019-2023 Edge
Engine: 2.7L EcoBoost
Lincoln
2019-2023 Nautilus
Summary
This TSB supersedes TSB 22-2376 to update the model years affected.
Issue: Some 2019-2023 Edge/Nautilus vehicles equipped with a 2.7L EcoBoost engine may exhibit a ticking/tapping or rattle type noise from the top front cover area of the engine on initial start-up after a cold soak of 6 hours or more that may last for 2-5 seconds. This may be due to stuck internal components of the variable cam timing (VCT) unit. To correct the condition, follow the Service Procedure to replace the VCT units.
Action: Follow the Service Procedure to correct the condition on vehicles that meet all of the following criteria:
• 2019-2023 Edge/Nautilus
• 2.7L EcoBoost engine
• Customer symptom of ticking/tapping or rattle noise from the front cover area after a cold start
NOTE: Dealers should only order parts for customer vehicles that require repairs. Because of part constraints, dealers may experience situational short-term backorders on some parts. Customers should continue to drive vehicles while parts are on order.
Parts
All Vehicles - Required Parts
Service Part Number Quantity Description Unit of Issue Piece Quantity
CP9Z-6279-C 4 VCT Unit Bolts 1 4
FT4Z-6A340-A 1 Crankshaft Pulley Bolt 1 1
KU2Z-6731-A 1 Engine Oil Filter 1 1
JT4Z-6710-A 1 Oil Pan Press-In-Place Gasket 1 1
KT4Z-6710-A 1 Oil Pan Gasket 1 1
FT4Z-6626-A 1 Oil Pump Seal 1 1
FT4Z-6020-G 1 Coolant Pump Gasket 1 1
FT4Z-8507-C 1 Coolant Pump Seal 1 1
XW4Z-6700-B 1 Crankshaft Front Oil Seal 1 1
FT4Z-6020-K 1 Engine Front Cover Gasket 1 1 1
FT4Z-6020-H 1 Engine Front Cover Gasket 2 1 1
FT4Z-6020-J 1 Engine Front Cover Gasket 3 1 1
FT4Z-6020-A 1 Engine Front Cover Gasket 4 1 1
FT4Z-00815-C 1 Oil Gallery Seal 1 1
L1MZ-6256-C 2 VCT Unit - Intake 1 2
L1MZ-6C525-C 2 VCT Unit - Exhaust 1 2
BL3Z-9450-A 2 Catalytic Converter Gasket 1 2
FT4Z-6584-D 1 Left Valve Cover Gasket 1 1
FT4Z-6584-B 1 Right Valve Cover Gasket 1 1
FT4Z-6584-C 1 Left Valve Cover Gasket 1 1
FT4Z-6584-E 1 Right Valve Cover Gasket 1 1
1X4Z-9E936-AA 1 Throttle Body Gasket 1 1
DL3Z-19B596-B 1 A/C O-Ring Kit 1 1
DS7Z-19B596-A 1 A/C Gasket Kit 1 1
W712334-S440 2 Engine Mount Bracket-To-Engine Nuts 3 4
W717674-S439 1 Engine Mount-To-Frame Bolts 4 2
W710807-S442 1 Engine Mount-To-Frame Nut 4 1
W716457-S439 1 Subframe Bolts 4 2
W712458-S900 1 Exhaust Studs 4 4
W714265-S442 1 Catalytic Converter To Turbo Flange Nuts 4 4
VC-13DL-G As Needed Motorcraft® Yellow Prediluted Antifreeze/Coolant (All Markets Except Canada)
CVC-13DL-G As Needed Motorcraft® Yellow Prediluted Antifreeze/Coolant (Canada Only)
XO-5W30-Q1SP As Needed Motorcraft® SAE 5W-30 Synthetic Blend Motor Oil (All Markets Except Canada)
CXO-5W30-LSP6 As Needed Motorcraft® SAE 5W-30 Super Premium Motor Oil (Canada Only)
XL-2 As Needed Motorcraft® High Temperature Nickel Anti-Seize Lubricant
ZC-37-A As Needed Motorcraft® Wheel and Tire Cleaner
XL-1 As Needed Motorcraft® Penetrating and Lock Lubricant
TA-26 As Needed Motorcraft® Threadlock 262
YN-35 As Needed Motorcraft® R-1234yf Refrigerant PAG Oil
TA-357 As Needed Motorcraft® High Performance Engine RTV Silicone
Parts
Nautilus Only Parts
W712961-S450B 1 Steering Shaft Coupler Bolt 4 1
W520215-S440 1 Tie Rod Nut 4 2
W712503-S440 2 Stabilizer Bar Nuts 1 2
W520214-S440 1 Ball Joint Nut 2 2
W500545-S439 1 Ball Joint Stud 4 2
W717016-S439 1 Rearward Subframe Bolt 4 2
Parts
All Vehicles - Parts To Inspect And Replace Only If Necessary
FT4Z-6A832-C If Needed Oil Filter Housing And Stem 1
BR3Z-6C535-B If Needed Spark Plug Seals 1
Quantity refers to the amount of the service part number required to repair the vehicle.
Unit of Issue refers to the number of individual pieces included in a service part number package.
Piece Quantity refers to the total number of individual pieces required to repair the vehicle.
As Needed indicates the amount of the part may vary and/or is not a whole number. Parts can be billed out as non-whole numbers, including less than 1.
If Needed indicates the part is not mandatory.
Warranty Status: Eligible under provisions of New Vehicle Limited Warranty (NVLW)/Emissions Warranty/Service Part Warranty (SPW)/Special Service Part (SSP)/Extended Service Plan (ESP) coverage. Limits/policies/prior approvals are not altered by a TSB. NVLW/Emissions Warranty/SPW/SSP/ESP coverage limits are determined by the identified causal part and verified using the OASIS part coverage tool.
Labor Times
Description Operation No. Time
2019-2023 Edge AWD 2.7L EcoBoost, Nautilus FWD/AWD 2.7L EcoBoost: Replace All 4 VCT Units (Do Not Use With Any Other Labor Operations) 232049A 14.7 Hrs.
Repair/Claim Coding
Causal Part: 6C525
Condition Code: 42
Service Procedure
1. Replace all 4 VCT units. Refer to Workshop Manual (WSM), Section 303-01. Do not replace any additional VCT or engine timing-related components not included in the Parts List.
(1). All the VCT solenoid and spark plug tube seals require inspection, but not all require replacement.
© 2023 Ford Motor Company
All rights reserved.
NOTE: The information in Technical Service Bulletins is intended for use by trained, professional technicians with the knowledge, tools, and equipment to do the job properly and safely. It informs these technicians of conditions that may occur on some vehicles, or provides information that could assist in proper vehicle service. The procedures should not be performed by "do-it-yourselfers". Do not assume that a condition described affects your car or truck. Contact a Ford or Lincoln dealership to determine whether the Bulletin applies to your vehicle. Warranty Policy and Extended Service Plan documentation determine Warranty and/or Extended Service Plan coverage unless stated otherwise in the TSB article. The information in this Technical Service Bulletin (TSB) was current at the time of printing. Ford Motor Company reserves the right to supersede this information with updates. The most recent information is available through Ford Motor Company's on-line technical resources.
Edited by Haz
Thanks Haz.  I have a 22ST with the 2.7 and posted this question below when this was initially published by you in December.  I still hear a fast clicking/tapping noise from my engine, but it isn't limited to when it first starts as it always does it......here is what I wrote below.....
I have a 22 ST with the 2.7.  I don't necessarily hear this tapping or rattle noise on start up, but I do think that the engine is a bit noisy when you are outside the vehicle with it running and standing in front of it.  It does seem to make a constant fast clicking noise all the time on mine.  I attributed this to fuel injection or something else "normal" as it runs smoothly to me.  It doesn't make any different noise the first 5 seconds than it does all the time.  I also wonder what the problem is if it only does it, as reported, for 2 to 5 seconds after it starts, is there really a problem?  Is it harming the engine?
If anyone has the misfortune of having to deal with the Cold Start Ticking/Tapping Or Rattle Type Noise associated with the issue documented in this TSB, please post an audio file so that we all know what we should be listening for. Thank you.
Could this be the problem?  I realize this is a 2.0L Ecoboost in the video, but like he says, this rattle he refers to is not an engine problem it a turbo problem and could easily happen to a 2.7L Ecoboost.  Not sure if this is your problem but at least you can compare the sound.  HTH
The noise described as "not detrimental to engine function, [having] no effect on engine durability, [and] aoperating characteristic of these engines" in SSM 51465 - 2019-2023 Various Vehicles - 2.0L/2.3L EcoBoost - Light To Moderate Ticking Type Noise At Idle (600-700 RPM) is attributed to those EcoBoost engines' High Pressure Fuel Pump.
Perhaps it's that same component you're hearing on your 2.7L EcoBoost, as shown in the 2019 Edge Workshop Manual...
2.7L EcoBoost Fuel Charging and Controls - Component Location
1158539816_FuelChargingandControls-ComponentLocation-2.7LEcoBoost-2019EdgeWorkshopManual.thumb.jpg.e3f99b9a322a689c1fc21c8d5cfd4430.jpg
395859539_FuelChargingandControls-ComponentLocationLEGEND-2.7LEcoBoost-2019EdgeWorkshopManual.jpg.7b84f6b2c002b6a4340441c777392210.jpg
1807394126_HighPressureFuelPump-ConnectorC119Location-2.7LEcoBoost-2019EdgeWorkshopManual.thumb.jpg.18e2021fabdc96da8cd08f467e76df48.jpg
Document download link> High Pressure Fuel Pump - Removal and Installation - 2019 Edge Workshop Manual.pdf
Good luck!
Edited by Haz
  • 10 months later...
TSB 23-2356 has been issued, effective February 23, 2024, and it supercedes the above-posted TSB 23-2049, due to updates in the Parts List...
Document download link> TSB 23-2356 - 20019-2023 Edge-Nautilus - 2.7L EcoBoost - Cold Start Ticking-Tapping Or Rattle Type Noise.pdf
23-2356
23 February 2024
This bulletin supersedes 23-2049.
Model:
Ford
2019-2023 Edge
Lincoln
2019-2023 Nautilus
Summary
This article supersedes TSB 23-2049 to update the parts list.
• 2.7L EcoBoost
Parts - All Vehicles - Required Parts
FT4Z-00815-C 1 Oil Seal 1 1
FT4Z-00815-A 1 Oil Gallery Seal 1 1
W716457-S439 1 Subframe Bolts 4 4
ZC-30-A As Needed Motorcraft® Gasket Remover
ZC-31-B As Needed Motorcraft® Metal Surface Prep Wipes
PM-4-A As Needed Motorcraft® Metal Brake Parts Cleaner (Compliant With Low Volatile Organic Compound Requirements As Required In Some USA States)
PM-4-B As Needed Motorcraft® Metal Brake Parts Cleaner (Not Compliant With Volatile Organic Compound Requirements)
ZC-20 As Needed Motorcraft® Engine Shampoo and Degreaser
Parts - Nautilus Only Parts
Parts - All Vehicles - Parts To Inspect And Replace Only If Necessary
Labor Times
2019-2023 Edge AWD 2.7L EcoBoost, Nautilus FWD/AWD 2.7L EcoBoost: Replace All 4 VCT Units (Do Not Use With Any Other Labor Operations) 232356A 14.7 Hrs.
Repair/Claim Coding
Causal Part: 6C525
Condition Code: 42
Service Procedure
© 2024 Ford Motor Company
Edited by Haz
  • 3 months later...
I have a 2020 Edge ST with just over 76,000 miles on it and I've noticed a rattling sound coming from the top of the engine after a cold start and any time the RPMs drop. After doing a bit of research, I found a TSB (23-2049) which basically says the VCT units may be stuck. I've been googling for days and found nobody with an Edge having this issue. There's plenty of F-150s with the issue though. Has anyone ever experienced this on their Edge? If so, how much did it cost to fix it? Do I have to pull the motor in order to do it? Should I do the timing chains as well? Thanks.
2.7L TSB.pdf
  • 1004ron changed the title to 2020 Edge ST 2.7L VCM Rattle - TSB 23-2049
Welcome to the Forum @Snub_Nose_Edge!
To provide you a glimpse of the scope of work involved in TSB 23-2346/TSB 23-2049, attached below as PDF documents are some -- but not all -- of 2020 Edge Workshop Manual sections involved in performing the repair...
Please note that some of the numbered action-step descriptions which precede their associated illustrations may appear on the page before their rightfully associated illustrations.
I invite other Forum members to respond to your additional questions.
Variable Camshaft Timing (VCT) Unit - Removal and Installation - 2.7L EcoBoost - 2020 Edge Workshop Manual.pdf Timing Chain - Removal and Installation - 2.7L EcoBoost - 2020 Edge Workshop Manual.pdf
Edited by Haz
Thank you for those portions of the service manual @Haz. Unfortunately, I don't have the tools needed to complete this, so I have to send it out to get done ☹️. I got quoted about $3,300 to have it repaired by my local Ford dealer, that was the best price I could get. I spoke with a mechanic and he did say the VCT units have an updated design that should prevent this issue in the future, I'm hopeful that is the case.
