Ryoung226 Posted March 15, 2023 Report Share Posted March 15, 2023 Hello everyone I just bought my second 2012 edge limited it is loaded but on the screen there is no options for the backup camera which it does have but not working I think it might be a programming issue or something does anyone have any suggestions? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted March 16, 2023 Report Share Posted March 16, 2023 Yeah, I don't think there is any way to enable or disable it, just some of the options (like guidelines, parking alert (if equipped), and delay. These are in the Vehicle settings (left display/controls on left of steering wheel Menu>Vehicle>Rear View Camera). Only reason it should not display is if the lift gate isn't closed, but it should show a message about that. Quote Link to comment Share on other sites More sharing options...
Perblue Posted March 16, 2023 Report Share Posted March 16, 2023 The camera is either dead or has a bad wire some where. Quote Link to comment Share on other sites More sharing options...
Ryoung226 Posted March 16, 2023 Author Report Share Posted March 16, 2023 22 hours ago, Ryoung226 said: Hello everyone I just bought my second 2012 edge limited it is loaded but on the screen there is no options for the backup camera which it does have but not working I think it might be a programming issue or something does anyone have any suggestions? There is no options at all I can go to settings/vehicle then there is no option for backup camera Quote Link to comment Share on other sites More sharing options...
Ryoung226 Posted March 16, 2023 Author Report Share Posted March 16, 2023 1 hour ago, Perblue said: The camera is either dead or has a bad wire some where. But shouldn't it still show up in the settings? Quote Link to comment Share on other sites More sharing options...
Perblue Posted March 17, 2023 Report Share Posted March 17, 2023 3 hours ago, Ryoung226 said: But shouldn't it still show up in the settings? Nope, there were none in my 2013. What does your screen show when you put it in reverse? Quote Link to comment Share on other sites More sharing options...
Ryoung226 Posted March 17, 2023 Author Report Share Posted March 17, 2023 5 hours ago, Perblue said: The camera is either dead or has a bad wire some where. 37 minutes ago, Perblue said: Nope, there were none in my 2013. What does your screen show when you put it in reverse? It just stays the same on the home screen Quote Link to comment Share on other sites More sharing options...
Perblue Posted March 17, 2023 Report Share Posted March 17, 2023 2 hours ago, Ryoung226 said: It just stays the same on the home screen Ok that is odd. Maybe this thread will help Rearview camera doesn't come on - Audio, Backup, Navigation & SYNC - Ford Edge Forum Quote Link to comment Share on other sites More sharing options...
Ryoung226 Posted March 17, 2023 Author Report Share Posted March 17, 2023 (edited) I's there some sort of module that could be bad or a program issue maybe? Edited March 17, 2023 by Ryoung226 Quote Link to comment Share on other sites More sharing options...
Perblue Posted March 17, 2023 Report Share Posted March 17, 2023 2 hours ago, Ryoung226 said: I's there some sort of module that could be bad or a program issue maybe? That would more than likely be the camera itself. 2 times my camera acted up, both different, both times it was the camera. Quote Link to comment Share on other sites More sharing options...
Ryoung226 Posted March 18, 2023 Author Report Share Posted March 18, 2023 But would that remove it from the sync system? Quote Link to comment Share on other sites More sharing options...
Perblue Posted March 18, 2023 Report Share Posted March 18, 2023 2 hours ago, Ryoung226 said: But would that remove it from the sync system? My problems didn't but no idea. Did you try the stuff in that post? You could also see if you sync version is up to date for your vehicle and update it if not. Update Ford SYNC® & Navigation Maps | Ford Owner Support Quote Link to comment Share on other sites More sharing options...
