lildisco Posted February 20, 2023 Report Share Posted February 20, 2023 Owners manual states 75W, but would Redline lightweight Shockproof work? Is going to be by first swap & I already bought some for the front PTU & getting ready for a road trip. Just wanted make sure that it would be OK. Currently just below 18,000. FordTechMakuloco says that it's specific 75W from Ford so I'm not sure if the ol smurf blood is compatible. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 20, 2023 Report Share Posted February 20, 2023 Looking how Ford's oil is specific to this application, I wouldn't recommend using a "regular" gear oil in its place. Link to Motorcraft page for this oil. It also states "Do not use in conventional high-offset hypoid gear axles where SAE 75W-85, 75W-90, 80W-90 or 75W-140 is recommended". 3 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 20, 2023 Author Report Share Posted February 20, 2023 Thanks! I thought that Redline was expensive ? Motorcraft XY-75W-QL is over double the cost for 1 qt 1 Quote Link to comment Share on other sites More sharing options...
JGN12 Posted February 20, 2023 Report Share Posted February 20, 2023 I'm very interested why you're planning to change this fluid. Trying to get my head around my manual's scheduled maintenance for this being "never, unless it shows sign of leakage," and my local dealer's recommendation that the manual's "never needs servicing" is nonsense and it should be changed every 50,000 miles or so, and you're changing at 18,000 miles? Please let me know what you've heard and why you're changing it. Thanks Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 20, 2023 Author Report Share Posted February 20, 2023 33 minutes ago, JGN12 said: I'm very interested why you're planning to change this fluid. Trying to get my head around my manual's scheduled maintenance for this being "never, unless it shows sign of leakage," and my local dealer's recommendation that the manual's "never needs servicing" is nonsense and it should be changed every 50,000 miles or so, and you're changing at 18,000 miles? Please let me know what you've heard and why you're changing it. Thanks 1 Quote Link to comment Share on other sites More sharing options...
JGN12 Posted February 20, 2023 Report Share Posted February 20, 2023 Thank you for the reply- I appreciate it. I, personally, find his analysis unconvincing and ill-informed but that's just my opinion and he has his, and I get it and respect it. I'm still reluctant to go with the manual saying "never unless you see leaks, but I'm also an engineer that designs mechanical systems and I have written specified maintenance schedules on my own systems because I understand them better than a layman; so I'm reluctant to spend money and waste resources if it's not necessary. Still researching and learning... Thank you again! Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 20, 2023 Author Report Share Posted February 20, 2023 Seeing how the fluid goes in light brown & comes out black or gray is enough for me to swap it out. Not to mention the shavings caught on each plug. 1 Quote Link to comment Share on other sites More sharing options...
JGN12 Posted February 21, 2023 Report Share Posted February 21, 2023 Thank you for your insight. I'm still reluctantly going to go with the "never unless it leaks" until and unless I see some good quantitative data showing the Ford engineering mx schedule is flawed. I get everything you're saying and what the mechanics are saying, but I'm a mechanical engineer that's spec'd complex systems myself and I also have 20 years experience looking at USAF SOAP/JOAP chemical oil samples of jet engines and helicopter transmissions and analyzing them to determine mx schedules. There's much more than gut feel based on color and shavings. That being said, there's absolutely NOTHING wrong with changing lubrication more often than spec'd. It will indeed lead to increased life every single time. The question is an economic and environmental question- should you change much more frequently to get a (maybe) longer life at greater expense or change according to the schedule to reduce expense and environmental impact. It's the user's choice and like I said, I'm interested why you chose the former. I understand it and appreciate it, but it's not yet for me. Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 21, 2023 Author Report Share Posted February 21, 2023 (edited) 2 hours ago, JGN12 said: Thank you for your insight. I'm still reluctantly going to go with the "never unless it leaks" until and unless I see some good quantitative data showing the Ford engineering mx schedule is flawed. I get everything you're saying and what the mechanics are saying, but I'm a mechanical engineer that's spec'd complex systems myself and I also have 20 years experience looking at USAF SOAP/JOAP chemical oil samples of jet engines and helicopter transmissions and analyzing them to determine mx schedules. There's much more than gut feel based on color and shavings. That being said, there's absolutely NOTHING wrong with changing lubrication more often than spec'd. It will indeed lead to increased life every single time. The question is an economic and environmental question- should you change much more frequently to get a (maybe) longer life at greater expense or change according to the schedule to reduce expense and environmental impact. It's the user's choice and like I said, I'm interested why you chose the former. I understand it and appreciate it, but it's not yet for me. Not knocking you either. The previous Gen PTU's also stated that they didn't need serviced. Do a little bit of research on the previous Gen PTU issues & you can see that their recommendations/service intervals aren't always accurate. Edited February 21, 2023 by lildisco 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted February 21, 2023 Report Share Posted February 21, 2023 2 hours ago, lildisco said: Not knocking you either. The previous Gen RDU's also stated that they didn't need serviced. Do a little bit of research on the previous Gen RDU issues & you can see that their recommendations/service intervals aren't always accurate. If I'm not mistaken, the previous generation issues were from the PTU. RDU failures are rare. As for @JGN12 point on maximum maintenance life, comparing vehicles (Ford) to other complex systems (including aeronautical), the difference lies, in my opinion, in designed service life. Planes & helicopters I believe are designed to serve a much longer life than automobiles. 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 21, 2023 Author Report Share Posted February 21, 2023 37 minutes ago, omar302 said: If I'm not mistaken, the previous generation issues were from the PTU. RDU failures are rare. You are correct sir. Edited my post to relate. That's what I get for trying to multitask while getting the kid ready for bed. 2 Quote Link to comment Share on other sites More sharing options...
JGN12 Posted February 21, 2023 Report Share Posted February 21, 2023 omar302, As to your first point re: PTU vs RDU, I have no knowledge about that. As to your second point, you're correct that generally speaking (but not always), complex industrial and military mechanical systems are designed to an indefinite life with mx schedules designed accordingly to support an indefinite life. That begs the question, what did Ford intend for it's Edge when it specified NO lubrication service on the AWD system unless it showed leakage, yet, they're specifying 200,000 miles or 10 years initial replacement of engine coolant. To me, that indicates they're obviously looking way, way beyond 200K miles and 10 years for the AWD servicing. I think they may have designed a mechanical unit that just needs some lubrication but is irrelevant about flaking or minor mechanical wear. Just my thinking from my experience as a designer and an educated consumer. They would never be motivated to recommend something that proves them wrong. I think it's possible they invented the equivalent of the "sealed roller bearing" in a gearbox. When the un-serviceable sealed roller bearing came out, lots of folks threw down the red flag saying it was impossible. Just a thought. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 21, 2023 Report Share Posted February 21, 2023 Having a semi related PTU is a similar vehicle (2012 Fusion Sport AWD 3.5 with an awf21 transmission), with no drain plug, and having that thick viscous goop forced out the vent, I wish it wasn't at 110,000 miles that I got it, and could have gotten to it sooner. I filled and removed as much "fluid" as I could a few times (no drain, so sucking out the nasty stuff), it has never been noisy that I can tell, and now that it mostly has fresh gear lube filled to where it should be, it hasn't been messy again. This is what I found after parking on the same place a few nights in a row: This is the best view I could get of the top of the transmission at the vent, a puddle of it: 1 Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted February 22, 2023 Report Share Posted February 22, 2023 (edited) On 2/20/2023 at 10:47 PM, dabangsta said: ... PTU is a similar vehicle (2012 Fusion Sport AWD 3.5 with an awf21 transmission) ...no drain plug ...goop forced out the vent ...at 110,000 miles ...removed as much "fluid" as I could a few times...sucking out the nasty stuff ...never been noisy ...now that it mostly has fresh gear lube filled to where it should be, it hasn't been messy again. ...found after parking on the same place a few nights in a row: ...view I could get of the top... Yep, your PTU GearOil went too long without being renewed; likely at least some bearing damage, But may have caught soon enough it to keep it alive+running; recommend the following: * Drill+Tap drain in PTU bottom, install Fumoto DrainValve. * Remove Cap+Rubber1WayValve from TopVent leaving a HoseBarb, install VentHose up to under Hood between Battery & FuseBox. * Remove RightSidePlug, install 90degElbow+FillHose up to under Hood between Battery & FuseBox. * Install Combo FillCan+VentFilter under Hood between Battery & FuseBox, connecting above 2 Hoses. * Drain+Renew PTU Oil via above items, HiTemp AmsOil or RedLine 75w140.FullSyn, every 6mths along with routine Engin Oil+Filter change. May want to prepare yourself+budget for replacing PTU if it decides to die. Also recommend above items when installing a new PTU. Edited February 27, 2023 by 1004ron 3 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 24, 2023 Author Report Share Posted February 24, 2023 PTU done. I'll probably swap it again when I get closer to 30,000 1 1 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 25, 2023 Author Report Share Posted February 25, 2023 RDU done. Fluid wasn't terrible, but there was a lot of junk on the drain plug 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 25, 2023 Author Report Share Posted February 25, 2023 ~an hour of random driving, no leaks or unusual noises. Mission accomplished. I will say the fill hole plug is quite tricky to get a wrench on it. Had a breaker bar that wouldn't fit in all the way. Adequate pressure & patience is key. I'm sure someone with a larger tool arsenal might have something that can work better. Feel way better that it's done. Next up will probably be a transmission Drain & fill once we get back from vacation 1 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 27, 2023 Report Share Posted February 27, 2023 On 2/20/2023 at 9:18 PM, omar302 said: If I'm not mistaken, the previous generation issues were from the PTU. RDU failures are rare. As for @JGN12 point on maximum maintenance life, comparing vehicles (Ford) to other complex systems (including aeronautical), the difference lies, in my opinion, in designed service life. Planes & helicopters I believe are designed to serve a much longer life than automobiles. yeah 2011+ have more problems with the RDUs than 2007-2010. probably because they changed awd programming to get that quicker rwd style launch without upgrading the internals significantly. increased vehicle power as well ... definitely not lack of fluid or airflow. the taurus sho 2010+ also experiences rdu issues. but i have seen only 1 person so far (may he RIP) that has installed a drain plug on it. Quote Link to comment Share on other sites More sharing options...
1004ron Posted February 27, 2023 Report Share Posted February 27, 2023 On 9/18/2021 at 5:20 PM, 1004ron said: Today I did the second RDU oil change and this time I extracted more of the old oil than the previous time. I attached a section of flexible silicone tubing to my oil extractors tubing with about 12" of coat hanger wire inside the tube, so that I could form a shepherds hook. The look of the oil each time I've changed it, I'd say you can safely follow the owners manual, and forget about changing the RDU oil. I've got 90K miles on mine and have changed the RDU oil three times and the above mentioned method extracts just about the full volume of oil. The last fill I used Amsoil SEVERE GEAR® 75W-90 My RDU oil has looked like new each time. 2 Quote Link to comment Share on other sites More sharing options...
lildisco Posted February 27, 2023 Author Report Share Posted February 27, 2023 5 hours ago, 1004ron said: I've got 90K miles on mine and have changed the RDU oil three times and the above mentioned method extracts just about the full volume of oil. The last fill I used Amsoil SEVERE GEAR® 75W-90 My RDU oil has looked like new each time. Do you have a drain plug or just a fill plug? The 2019+ have a different requirement for RDU fluid of just 75W. Unless you're referring to WWWPerfA_ZN0W's comment Quote Link to comment Share on other sites More sharing options...
lildisco Posted July 13 Author Report Share Posted July 13 (edited) Nearly 13,000 (12,726) mile update. Fluid came out a nice light brown color. Magnet had some dark material on it (which still could have been leftovers from the first drain & fill), but the fluid wasn't nearly has nasty as the 1st time. I did by a cheap Amazon special nearly flat 3/8 wrench that made the job much easier. It was $10 so wasn't too bad. Cleaned off both plugs & refilled. Still had some left from the 1st time I did it as well as a full fresh quart. Nearly took all of the fresh quart, but she's clean & ready to go. I saw on the Maverick forums that they were changing theirs every 5,000 miles, which seems to be extreme, but maybe they haul more than me? Dunno. 'Cheap' insurance at ~$40 quart & 30 minutes of your time. Edited July 13 by lildisco 2 Quote Link to comment Share on other sites More sharing options...
