katmus Posted February 18, 2023 Report Share Posted February 18, 2023 I just got new tires for my 2020 Edge Titanium with the Elite package. It has 20" polished aluminum wheels. I was shocked that the tech who replaced the tires said that my wheels have excessive rust, corrosion, and debris on the hub and wheel mating surfaces. They said this condition can cause the wheel to come loose. I'm horrified. I've never had an issue with wheels before. Is there a known issue with these wheels? Is it covered under warranty? I plan on taking it to a Ford service center, but I'm in Florida and have a lot of driving to do to get back to PA. Thanks for any feedback. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 18, 2023 Report Share Posted February 18, 2023 I assume that where you live has an environment that might cause more corrosion than what the person in Florida is used to? I get parts from people and I live in the desert southwest and I consider them trash, but are sold as "light corrosion" or "surface rust" from back east. I might just be they are not used to cleaning up the tire bead area and the wheel mating surface or rotor hub and applying anti-seize to the faces (not the lugs). Probably nothing specific to the wheel, I am sure that the same surface treatment is found on all aluminum wheels, and they touch dissimilar metal on the rotor hats. Quote Link to comment Share on other sites More sharing options...
Perblue Posted February 18, 2023 Report Share Posted February 18, 2023 Where the heck do you live? I'd like to see pictures of this excessive rust, you should see what hubs look like after a Canadian winter or 2. I doubt it's anything to worry about and your shop is trying to scare you. Quote Link to comment Share on other sites More sharing options...
katmus Posted February 18, 2023 Author Report Share Posted February 18, 2023 Thanks for the comments. They make sense. I live in PA and they use a lot of road salt there. The tire tech that installed my tires is from Florida so they probably aren't used to seeing the corrosion from road salt as you said. I'll still get them checked out though when I'm back in PA. They look fine from the outside. Quote Link to comment Share on other sites More sharing options...
handfiler Posted February 19, 2023 Report Share Posted February 19, 2023 This is what I did to prevent the rust: https://www.fordedgeforum.com/topic/13407-what-have-you-done-towith-your-edgemkx-today/?do=findComment&comment=222524 1 Quote Link to comment Share on other sites More sharing options...
Perblue Posted February 19, 2023 Report Share Posted February 19, 2023 1 hour ago, handfiler said: This is what I did to prevent the rust: https://www.fordedgeforum.com/topic/13407-what-have-you-done-towith-your-edgemkx-today/?do=findComment&comment=222524 LOL I've used anti seize on a lot of stuff but never considered that at all! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 21, 2023 Report Share Posted February 21, 2023 Do you live near to coast? Salt air can be corrosive. Quote Link to comment Share on other sites More sharing options...
