Johnboy23 Posted February 17, 2023 Report Share Posted February 17, 2023 The steering wheel will not turn sometimes in cold weather below 32. Feels like the steering wheel is locked but seems when it warms up it is fine. Wondering if anyone has run into it 2018 Ford Edge FWD 3.5 Thanks! Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 17, 2023 Report Share Posted February 17, 2023 That is even weirder to me on a vehicle with EPAS. My older hydraulic system cars could be stiff and noisy when really cold, but not driven an EPAS vehicle in the cold, but I wouldn't expect an electric motor to suffer like a fluid pump. Quote Link to comment Share on other sites More sharing options...
Johnboy23 Posted February 18, 2023 Author Report Share Posted February 18, 2023 My wife washes the car weekly at an automatic car wash. It does wash the underside. I'm wondering if water is getting inside the boot and freezing up? Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 18, 2023 Report Share Posted February 18, 2023 Might not even be mechanical, could be water intrusion into the connector to the rack, however that will usually throw a message on the dash. If the power assist is out, it is still driveable, but pretty hard to turn, especially when stationary. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted February 19, 2023 Report Share Posted February 19, 2023 The first thing I would suspect is a weak vehicle battery. You need to test the battery's CCA capability. If the battery is getting weak, it loses capacity and voltage in the cold. After the car starts, the voltage comes up due to the alternator and the steering will begin working again. Quote Link to comment Share on other sites More sharing options...
Johnboy23 Posted February 22, 2023 Author Report Share Posted February 22, 2023 Problem solved. Boot had a small tear and water was inside. Freezing so it wouldn't turn but also had quite a bit of rust inside . The last day or so they were getting rough spots as you turned the wheel. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
DRLaR Posted December 20, 2024 Report Share Posted December 20, 2024 On 2/22/2023 at 12:33 PM, Johnboy23 said: Problem solved. Boot had a small tear and water was inside. Freezing so it wouldn't turn but also had quite a bit of rust inside . The last day or so they were getting rough spots as you turned the wheel. Thanks! I am having the same issue with mine I was wondering where exactly this boot was located? Thanks. Quote Link to comment Share on other sites More sharing options...
