EDM93 Posted January 30, 2023 Report Share Posted January 30, 2023 Hello! I have a 2008 edge, i drove it to work this morning and everything was fine. Came out to go home and it wouldnt start, acted like the battery was dead but i had dash lights on. I tried to jump it and it would crank but no dice. I took the battery in to get tested(it ended up being dead) so i had oreillys charge and test it. Everything came back good. I reinstalled it, then my dash lights came on, radio was on, headlights came on. But car wouldnt start, no crank, nothing. Anyone ever have this issue before? Im stumped. Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted February 1, 2023 Report Share Posted February 1, 2023 (edited) how old is the battery? can you post a pic of what you have, including mfr date if still on there? use a digital tester like the solar ba9 to test battery alternator starting system yourself. store testing of batteries is weak sauce. i would replace the battery. also, if the PATS light is flashing fast when you attempt to start, you may need a new fob or get it reprogrammed to the vehicle. Edited February 1, 2023 by WWWPerfA_ZN0W Quote Link to comment Share on other sites More sharing options...
EDM93 Posted February 1, 2023 Author Report Share Posted February 1, 2023 Issue has been resolved. It was a bad ignition switch. 1 1 Quote Link to comment Share on other sites More sharing options...
