Victor Posted January 19, 2023 Report Share Posted January 19, 2023 (edited) So my 2009 Edge Limited just reached 130,000 miles. Any recommendations maintenance wise? Edited January 19, 2023 by 1004ron Quote Link to comment Share on other sites More sharing options...
dabangsta Posted January 19, 2023 Report Share Posted January 19, 2023 Is it all up to date for the previously required stuff? Coolant at 105,000? The transmission fluid is 150,000 but that is pretty long. PTU and rear diff also at 150,000 if AWD. Serpentine accessory drive belt also 150,000. 1 Quote Link to comment Share on other sites More sharing options...
DILLARD000 Posted January 21, 2023 Report Share Posted January 21, 2023 IgnitionPlugs, OxSensors, PCVVlave, Belts+BeltTensioner, CoolantHoses+Clamps+Radiator at 100kMiles\12yr intervals. PTU 75w140 GearOil, DIff 75w90 GearOil, Trans MerconV, Coolant+TStat+PressureCap, BrakePads at 33kMiles\4yr intervals. EnginOil+Filter, HandPump+Refill SteeringReservoir MerconV, HandPump+Refresh BrakeReservoir DOT4 at 5kMiles\6mth intervals. Don't believe Ford\Dealership claims of "LifeTime Fluids"! 1 Quote Link to comment Share on other sites More sharing options...
Victor Posted January 22, 2023 Author Report Share Posted January 22, 2023 On 1/19/2023 at 4:42 PM, dabangsta said: Is it all up to date for the previously required stuff? Coolant at 105,000? The transmission fluid is 150,000 but that is pretty long. PTU and rear diff also at 150,000 if AWD. Serpentine accessory drive belt also 150,000 Expand I’ve kept the oil changes up to date. Changing it every 6 months. I recently replaced the spark plugs as well. Oh and I did flush the coolant system a couple years back. Quote Link to comment Share on other sites More sharing options...
Victor Posted January 22, 2023 Author Report Share Posted January 22, 2023 On 1/21/2023 at 9:51 AM, DILLARD000 said: IgnitionPlugs, OxSensors, PCVVlave, Belts+BeltTensioner, CoolantHoses+Clamps+Radiator at 100kMiles\12yr intervals. PTU 75w140 GearOil, DIff 75w90 GearOil, Trans MerconV, Coolant+TStat+PressureCap, BrakePads at 33kMiles\4yr intervals. EnginOil+Filter, HandPump+Refill SteeringReservoir MerconV, HandPump+Refresh BrakeReservoir DOT4 at 5kMiles\6mth intervals. Don't believe Ford\Dealership claims of "LifeTime Fluids"! Expand Ok, I recently replaced the spark plugs and pcv valve. Besides that, looks like I have a lot of work ahead. Thanks for your input. 1 Quote Link to comment Share on other sites More sharing options...
