17Edge460 Posted December 24, 2022 Report Share Posted December 24, 2022 Hello All, I am new to the forum, my name is Jim and I have a 2017 Ford Edge Sport and I wanted to say Hi and ask a question. I have the panoramic sunroof feature on my Edge and recently it started leaking to an extent where there was water actively dripping from the roof as I was driving, with it closed and the shield closed as well. The water was dripping from the front electronic controls panel mounted on the roof. The car has 59,000 miles on it, and so far has given me no issues. I cannot find a TSB for this model year, has anyone else had this issue? If so what did you do? What do you recommend I should do? Thanks, Jim Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted December 26, 2022 Report Share Posted December 26, 2022 no tsb that i am aware of. typically with fords, the drains are blocked causing water to enter the cabin. the drains should exit under the door paneling. the entrance should be in the front of the sunroof one on each side. try blowing them out with compressed air. Quote Link to comment Share on other sites More sharing options...
