Haz Posted December 12, 2022 Report Share Posted December 12, 2022 Some 2015-2020 Edge, 2016-2018 MKX, 2019-2020 Nautilus, 2018-2021 Expedition/Navigator, and 2020-2021 Escape/Corsair/Explorer/Aviator vehicles may exhibit an inoperative power liftgate. This may be due to the rear gate trunk module (RGTM) software. To correct the condition, reprogram the RGTM using the latest software level of the appropriate Ford diagnostic scan tool. For claiming, use causal part 14B291 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual. This Special Service Message was released on December 12, 2022. 3 Quote Link to comment Share on other sites More sharing options...
Odrapnew Posted February 4, 2023 Report Share Posted February 4, 2023 Any chance there's a TSB number? My 18 Edge decided to stop opening liftgate(power). I opened liftgate with keyfob, loaded it and the closed again with the fob. Got home and tried to open with button on liftgate. Lights blink, but nothing happens. Tried the fob, button on dash, hands free, but nothing worked. Of course, my certified B-to-B expired 2 weeks ago. Quote Link to comment Share on other sites More sharing options...
dabangsta Posted February 4, 2023 Report Share Posted February 4, 2023 No TSB, it is an SSM. I don't know if this covers the failure you are reporting or not. https://static.nhtsa.gov/odi/tsbs/2021/MC-10198658-0001.pdf Is more 2019+ related I guess, and a possible fault code: https://static.nhtsa.gov/odi/tsbs/2021/MC-10201053-0001.pdf Quote Link to comment Share on other sites More sharing options...
Haz Posted February 4, 2023 Author Report Share Posted February 4, 2023 Relevant sections from the 2018 Edge Workshop Manual... Document download links> Liftgate Latch Manual Release - 2018 Edge Workshop Manual.pdfFetching info... Liftgate Latch - Removal and Installation - 2018 Edge Workshop Manual.pdfFetching info... Liftgate Trim Panel - Removal and Installation - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Initialization - 2018 Edge Workshop Manual.pdfFetching info... Power Rear Liftgate - Diagnosis and Testing - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Wiring Diagram 1 - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Wiring Diagram 2 - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Wiring Diagram 3 - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Wiring Diagram 4 - 2018 Edge Workshop Manual.pdfFetching info... Power Liftgate Wiring Diagram 5 - 2018 Edge Workshop Manual.pdfFetching info... Power Rear Liftgate - Component Location - 2018 Edge Workshop Manual.pdfFetching info... Power Rear Liftgate - System Operation - 2018 Edge Workshop Manual.pdfFetching info... Owner comments in this past discussion should be helpful to you. Good luck! 1 Quote Link to comment Share on other sites More sharing options...
Odrapnew Posted February 4, 2023 Report Share Posted February 4, 2023 (edited) I checked fuse to see if it was blown, it's still good. I tried opening the latch manually and am struggling. I got it to 'pop' but the liftgate will not open. The liftgate ajar light is on. I've tried pushing, pulling swearing, nothing is working. Any tips? Could the power lifgate motors be stuck? EDIT: it seems to me that the latch is only partially disengaged. When I lift the liftgate, it seems to catch at the latch. I can move it in/out a little bit, but just cannot get it to release all the way. I also read somewhere that a low battery might cause the liftgate to not open. Something about non-essential modules won't operate to save power. Resting voltage on the battery was around 11.8v, which is essentially dead for lead acid. I have my charger on it now and it was pulling about 5-6amps. It has been cold here for the last week and battery is original (5yrs old), so maybe it's due. All that still doesn't explain why I cannot manually open the liftgate. EDIT #2: I decided to pull the battery, bring inside to warm up and charge, then I'll bring it to Auto store to get tested. After I disconnected the battery, liftgate opened with no issue. I did lightly close it (which was partially latched) and manually open it again without issue. So, something electrical was keeping the latch from fully releasing....or possibly the power liftgate struts/motors? Regardless, I was able to open. Edited February 4, 2023 by Odrapnew Quote Link to comment Share on other sites More sharing options...
