2016+ Ford Edge Sport rear shock replacement procedure
rod.charlie
The swap is pretty easy. Just jack up the corner, remove the wheel, then you can access the bolts at the bottom of the shock and at the top. No need to mess with the spring or anything; that is, if you're talking about the 2.7 Edge Sport with AWD. You do need to remove the "bump stops" from the old shock and transfer them to the new one. I did this last year on my '15 Edge Sport. Super easy. Barely an inconvenience.
