BigPappa574 Posted November 28, 2022 Report Share Posted November 28, 2022 Hey Guys, First post. I have a on going issue w my Edge. While driving, especially highway, the temp goes up to around 220. Temp gage stays in the middle. As soon as I let off the gas and coast. Temp drops right back to 208ish. It has a new thermostat, and water pump. Turbo was replaced a month or so ago. I have drain and refilled it with the vacuum filling tool twice to confirm no air is in the system. The only visible coolant leak is right under the drain. I believe the pitcock needs replaced. Its only one or two tiny drops on the ground. I do have another one on order from Ford. Any help or direction is appreciated... Quote Link to comment Share on other sites More sharing options...
1004ron Posted November 28, 2022 Report Share Posted November 28, 2022 You suspect the loss of coolant is the petcock, but could be the issue discussed in the below thread. How are you measuring the temperature? Rough Idle When Cold/P0301 Code - coolant intrusion - TSB 22-2133 - Page 7 - 2.0L EcoBoost - Ford Edge Forum Quote Link to comment Share on other sites More sharing options...
BigPappa574 Posted November 28, 2022 Author Report Share Posted November 28, 2022 Thanks for the reply, I am checking the coolant temp w live data, along w my aftermarket radio. They both read the same. It is not setting any codes. Idling Fuel Trims LongTerm +23 SH Term +1 While Driving LongTerm +8 SH moves between -1 to +1 I also have access to Forscan. Quote Link to comment Share on other sites More sharing options...
