keiser Posted October 29, 2022 Report Share Posted October 29, 2022 I just acquired a 2014 Edge with 40,000 miles. It seems pristine. When I open the hood to check fluids after a drive, the hood prop almost burns my fingers. Temperatures, fluid levels normal. My last car was a 2005 Escape and I've owned Fords for 50 years. Is such a hot prop normal on this model? Quote Link to comment Share on other sites More sharing options...
omar302 Posted October 29, 2022 Report Share Posted October 29, 2022 It probably was very hot to the touch, if I remember correctly, and there even was a yellow plastic or rubber sleeve that you can hold the prop from to avoid touching the hot steel prop rod. See below photo: 1 Quote Link to comment Share on other sites More sharing options...
