Active Noise Control and Active Noise Cancellation
Tronjo
These are two different things. In Edge ST, the Active Noise Control seems to generate artificial engine noise in the cabin. The question is if ST is equipped with Active Noise Cancellation?
And if it is equipped with it, is it possible, using FORScan, to disable the Active Noise Control without affecting the Active Noise Cancellation?
Yes it has both and they are controlled by the same module. Disabling 1 disables them both.
Thank you Fingernip.
In FORScan 727-01-0X I found two fields related to ANC (F150 spreadsheet):
and
Does someone know if in 727-01-02 setting all to "No Mixing" will be equivalent to setting the corresponding field of 727-01-01 to "Not Present": xxxx x0xx xxxx?
Edited by Tronjo
