2022 Edge - code B108A:9E-C8
So my wife’s edge is acting strange.. if someone pushes the start button with out press brake it’s throwing a code. Unlike other edges that just say “press brake to start” so if someone jumps in her edge pushed the start button and don’t press brake it throws the code that does not go away unless it’s cleared..anyone seen this before?? It’s code B108A:9E-C8
Presuming you will have your dealer's Service department resolve this issue, this from the 2022 Edge Workshop Manual is just an FYI...
 BCM DTC Fault Trigger Conditions
B108A:9E Start Button: Signal Stuck On Sets continuous when the BCM detects only one switch input circuit indicating open when the start button is released.
Possible Causes
  • Battery voltage concern
  • Fuse
  • Wiring, terminals or connectors
  • PATS concern
  • Push button ignition switch
  • BCM
Good luck!
  • 1004ron changed the title to 2022 Edge - code B108A:9E-C8
