low speed ABS
Before replacing the speed sensors, did you scan or have your Edge scanned for Diagnostic Trouble Codes (DTCs) ?
The ABS module has an extensive list of DTCs that can be helpful toward pinpointing the cause of false ABS activation.
From the 2011 Edge Workshop Manual...
 ABS Module DTC Chart
DTC Description Action
C0001:49 TCS Control Channel "A" Valve 1: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0001:49 returns:
  • For vehicles without adaptive cruise control, INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
  • For vehicles with adaptive cruise control, INSTALL a new HCU . REFER to Hydraulic Control Unit (HCU) in this section. TEST the system for normal operation.
C0002:49 TCS Control Channel "A" Valve 2: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0002:49 returns:
C0003:49 TCS Control Channel "B" Valve 1: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0003:49 returns:
C0004:49 TCS Control Channel "B" Valve 2: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0004:49 returns:
C0010:49 Left Front Inlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0010:49 returns:
C0011:49 Left Front Outlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0011:49 returns:
C0014:49 Right Front Inlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0014:49 returns:
C0015:49 Right Front Outlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0015:49 returns:
C0018:49 Left Rear Inlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0018:49 returns:
C0019:49 Left Rear Outlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C0001:49 returns:
C001C:49 Right Rear Inlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C001C:49 returns:
C001D:49 Right Rear Outlet Control: Internal Electronic Failure This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C001D:49 returns:
C0020:11 ABS Pump Motor Control: Circuit Short To Ground This DTC indicates that part of the HCU has failed internally. CLEAR the DTCs. TEST DRIVE the vehicle. REPEAT the self-test. If C0020:11 returns, INSTALL a new HCU . REFER to Hydraulic Control Unit (HCU) in this section. TEST the system for normal operation.
C0020:12 ABS Pump Motor Control: Circuit Short To Battery This DTC indicates that part of the HCU has failed internally. CLEAR the DTCs. TEST DRIVE the vehicle. REPEAT the self-test. If C0020:12 returns, INSTALL a new HCU . REFER to Hydraulic Control Unit (HCU) in this section.
C0020:13 ABS Pump Motor Control: Circuit Open GO to Pinpoint Test A.
C0020:71 ABS Pump Motor Control: Actuator Stuck GO to Pinpoint Test A.
C0030:07 Left Front Tone Wheel: Mechanical Failure GO to Pinpoint Test B.
C0031:01 Left Front Wheel Speed Sensor: General Electrical Failure GO to Pinpoint Test D.
C0031:19 Left Front Wheel Speed Sensor: Circuit Current Above Threshold GO to Pinpoint Test D.
C0031:29 Left Front Wheel Speed Sensor: Signal Invalid GO to Pinpoint Test B.
C0031:2F Left Front Wheel Speed Sensor: Signal Erratic GO to Pinpoint Test B.
C0031:64 Left Front Wheel Speed Sensor: Signal Plausibility Failure GO to Pinpoint Test B.
C0033:07 Right Front Tone Wheel: Mechanical Failure GO to Pinpoint Test B.
C0034:01 Right Front Wheel Speed Sensor: General Electrical Failure GO to Pinpoint Test D.
C0034:19 Right Front Wheel Speed Sensor: Circuit Current Above Threshold GO to Pinpoint Test D.
C0034:29 Right Front Wheel Speed Sensor: Signal Invalid GO to Pinpoint Test B.
C0034:2F Right Front Wheel Speed Sensor: Signal Erratic GO to Pinpoint Test B.
C0034:64 Right Front Wheel Speed Sensor: Signal Plausibility Failure GO to Pinpoint Test B.
C0036:07 Left Rear Tone Wheel: Mechanical Failure GO to Pinpoint Test B.
C0037:01 Left Rear Wheel Speed Sensor: General Electrical Failure GO to Pinpoint Test D.
C0037:19 Left Rear Wheel Speed Sensor: Circuit Current Above Threshold GO to Pinpoint Test D.
C0037:29 Left Rear Wheel Speed Sensor: Signal Invalid GO to Pinpoint Test B.
C0037:2F Left Rear Wheel Speed Sensor: Signal Erratic GO to Pinpoint Test B.
C0037:64 Left Rear Wheel Speed: Sensor Signal Plausibility Failure GO to Pinpoint Test B.
C0039:07 Right Rear Tone Wheel: Mechanical Failure GO to Pinpoint Test B.
C003A:01 Right Rear Wheel Speed Sensor: General Electrical Failure GO to Pinpoint Test D.
C003A:19 Right Rear Wheel Speed Sensor: Circuit Current Above Threshold GO to Pinpoint Test D.
C003A:29 Right Rear Wheel Speed Sensor: Signal Invalid GO to Pinpoint Test B.
C003A:2F Right Rear Wheel Speed Sensor: Signal Erratic GO to Pinpoint Test B.
C003A:64 Right Rear Wheel Speed Sensor: Signal Plausibility Failure GO to Pinpoint Test B.
C0040:64 Brake Pedal Switch "A": Signal Plausibility Failure GO to Pinpoint Test E.
C0044:28 Brake Pressure Sensor "A": Signal Bias Level Out of Range/Zero Adjustment Failure GO to Pinpoint Test C.
C0044:49 Brake Pressure Sensor "A": Internal Electronic Failure GO to Pinpoint Test C.
C0044:64 Brake Pressure Sensor "A": Signal Plausibility Failure GO to Pinpoint Test C.
C0061:28 Lateral Acceleration Sensor: Signal Bias Level Out of Range/Zero Adjustment Failure This DTC indicates a concern with the lateral acceleration sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0061:64 Lateral Acceleration Sensor: Signal Plausibility Failure This DTC indicates a concern with the lateral acceleration sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0062:28 Longitudinal Acceleration Sensor: Signal Bias Level Out of Range/Zero Adjustment Failure This DTC indicates a concern with the longitudinal acceleration sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0062:64 Longitudinal Acceleration Sensor: Signal Plausibility Failure This DTC indicates a concern with the longitudinal acceleration sensor which is integral to the Restraints Control Module (RCM) . REFER toSection  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0062:76 Longitudinal Acceleration Sensor: Wrong Mounting Position This DTC indicates a concern with the longitudinal acceleration sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0063:28 Yaw Rate Sensor: Signal Bias Level Out of Range/Zero Adjustment Failure This DTC indicates a concern with the yaw rate sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0063:64 Yaw Rate Sensor: Signal Plausibility Failure This DTC indicates a concern with the yaw rate sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0064:28 Roll Rate Sensor: Signal Bias Level Out of Range/Zero Adjustment Failure This DTC indicates a concern with the roll rate sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C0064:64 Roll Rate Sensor: Signal Plausibility Failure This DTC indicates a concern with the roll rate sensor which is integral to the Restraints Control Module (RCM) . REFER to Section  501-20B to diagnose all the RCM DTCs. If no RCM DTCs are present, GO to Pinpoint Test K.
C1B00:29 Steering Angle Sensor: Signal Invalid This DTC sets when the ABS module receives invalid data from the SCCM regarding the steering wheel angle sensor input. RETRIEVE and REPAIR all non-network DTCs in the SCCM . REFER to Section  211-05.
C1B00:41 Steering Angle Sensor: General Checksum Failure The ABS module receives the steering wheel angle sensor information from the SCCM over the HS-CAN . CARRY OUT a self-test of the SCCM . REFER to Diagnosis and Testing in Section Section  211-05 to diagnose the DTCs retrieved.
C1B00:64 Steering Angle Sensor: Signal Plausibility Failure This DTC sets when the ABS module receives invalid data from the SCCM regarding the steering wheel angle sensor input. RETRIEVE and REPAIR all non-network DTCs in the SCCM . REFER to Section  211-05.
C1B00:86 Steering Angle Sensor: Signal Invalid This DTC sets when the ABS module receives invalid data from the SCCM regarding the steering wheel angle sensor input. RETRIEVE and REPAIR all non-network DTCs in the SCCM . REFER to Section  211-05
C1B14:11 Sensor Supply Voltage A: Circuit Short to Ground This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C1B14:11 returns:
C1B14:12 Sensor Supply Voltage A: Circuit Short to Battery This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C1B14:12 returns:
C1B14:1C Sensor Supply Voltage A: Circuit Voltage Out of Range This DTC indicates that part of the ABS module has failed internally. CLEAR the DTCs. REPEAT the self-test. If DTC C1B14:1C returns:
U0001:88 High Speed CAN Communication: Bus Off REFER to Section  418-00 to diagnose the network communication concern.
U0100:00 Lost Communication With ECM/PCM "A": No Sub Type Information GO to Pinpoint Test F.
U0104:00 Lost Communication With Cruise Control Module: No Sub Type Information GO to Pinpoint Test G.
U0140:00 Lost Communication With Body Control Module: No Sub Type Information GO to Pinpoint Test I.
U0151:00 Lost Communication With Restraints Control Module: No Sub Type Information GO to Pinpoint Test J.
U0151:88 Lost Communication With Restraints Control Module: Bus Off GO to Pinpoint Test K.
U0212:00 Lost Communication With Steering Column Control Module: Bus Off GO to Pinpoint Test H.
U0300:51 Internal Control Module Software Incompatibility: Not Programmed CONFIGURE the ABS module. CARRY OUT the PMI . REFER to Section  418-01. CLEAR the DTCs. REPEAT the self-test. If U0300:51 returns, INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module in this section. TEST the system for normal operation.
U0401:68 Invalid Data Received From ECM/PCM "A": Event Information This DTC sets when the ABS module receives invalid network data from the PCM. RETRIEVE and REPAIR all non-network DTCs in the PCM. REFER to Section  303-14.
U0405:68 Invalid Data Received From Cruise Control Module: Event Information This DTC sets when the ABS module receives invalid network data from the C-CM . RETRIEVE and REPAIR all non-network DTCs in the C-CM . REFER to Section  419-03A
U0420:68 Invalid Data Received From Power Steering Control Module: Event Information This DTC title refers to the SCCM not the Power Steering Control Module (PSCM) , this vehicle is equipped with an SCCM . This DTC sets when the ABS module receives invalid network data from the SCCM . RETRIEVE and REPAIR all non-network DTCs in the SCCM . REFER to Section  419-10.
U0422:68 Invalid Data Received From Body Control Module: Event Information This DTC sets when the ABS module receives invalid network data from the BCM . RETRIEVE and REPAIR all non-network DTCs in the BCM . REFER to Section  419-10.
U0452:68 Invalid Data Received From Restraints Control Module: Event Information This DTC sets when the ABS module receives invalid network data from the RCM . RETRIEVE and REPAIR all non-network DTCs in the RCM . REFER to Section  501-20B.
U2007:46 Valve(s): Calibration/Parameter Memory Failure CONFIGURE the ABS module. CARRY OUT PMI . REFER to Section  418-01. CLEAR the DTCs. REPEAT the self-test. If DTC U2007:46 returns:
U2100:00 Initial Configuration Not Complete: No Sub Type Information GO to Pinpoint Test P.
U2100:41 Initial Configuration Not Complete: General Checksum Failure GO to Pinpoint Test P.
U2100:55 Initial Configuration Not Complete: Not Configured GO to Pinpoint Test P.
U2101:00 Control Module Configuration Incompatible: No Sub Type Information GO to Pinpoint Test P.
U2107:00 Collision Mitigation By Braking: No Sub Type Information REFER to Section  419-03B.
U2108:62 Adaptive Cruise Control: Signal Compare Failure REFER to Section  419-03A.
U3000:41 Control Module: General Checksum Failure This DTC sets when there is a difference between the stability sensor information stored in the ABS module and the actual stability sensor information the ABS module receives from the RCM . Using a scan tool, CARRY OUT PMI on the ABS module using as-built data, then CARRY OUT PMI on the RCM using as-built data. Using a scan tool, CARRY OUT the IVD Initialization procedure. CLEAR the DTC. TEST DRIVE the vehicle at speeds greater than 20 km/h (12 mph). CARRY OUT an ABS module self-test. If the DTC returns and the vehicle is not equipped with adaptive cruise control, INSTALL a new ABS module. REFER to Anti-Lock Brake System (ABS) Module. If the DTC returns and the vehicle is equipped with adaptive cruise control, INSTALL a new ABS module and HCU . REFER to Hydraulic Control Unit (HCU)
U3000:43 Control Module: Special Memory Failure GO to Pinpoint Test P.
U3000:47 Control Module: Watchdog Safety Failure This DTC sets if the ABS module electrical connector is not fully seated and locked. DISCONNECT the ABS module. INSPECT the connector for bent or loose pins. If OK, RECONNECT. CLEAR the DTCs. REPEAT the self-test. If DTC U3000:47 is retrieved again:
U3000:49 Control Module: Internal Electronic Failure CLEAR the DTCs. CARRY OUT the ABS module self-test. RETRIEVE and RECORD any DTCs. If DTC U3000:49 is retrieved again:
U3000:4B Control Module: Over Temperature This DTC sets if the signal from the temperature sensor internal to the ABS module is out of range or is implausible when compared to the temperature sensors inside the HCU . Allow the vehicle to cool down for 15 minutes. CLEAR the DTCs. REPEAT the self-test. If DTC U3000:4B returns:
U3002:62 Vehicle Identification Number: Signal Compare Failure GO to Pinpoint Test L.
U3003:16 Battery Voltage: Circuit Voltage Below Threshold GO to Pinpoint Test M.
U3003:17 Battery Voltage: Circuit Voltage Above Threshold GO to Pinpoint Test N.
Good luck!
  • Thanks 1
Kind of sounds like a ABS sensor is dropping out at lower speeds. As you have already changed the sensors on all four wheels, did you check the tone ring on your front wheels? (Front because it only happens when turning). Check for cracks, broke teeth and some other physical damage. Also look to see how much brake dust has accumulated on the ring. Possibly the ring distorts when a left turn has initiated?
One other possibility is corrosion on the speed sensor connector(s). Making a weak signal.
Edited by enigma-2
Thank you Haz and enigma-2.  I didn't do a scan but I will now, since you were so kind to provide the DTC's.  Also, enigma-2, I didn't know about the tone rings issues until last night and until I had replaced the speed sensors.  This car is sooo rusty, I suspect there might be a cracked ring.  I'm not sure if this is the appropriate way to respond to the posts, but Thank you for your time!
  • Thanks 1
Left front, speed sensor or reluctor ring. The sensor reading from one wheel (the left front wheel in this case), is differing  from that of the other three wheels beyond a predefined limit while the vehicle is travelling in a straight line. Sets these codes.
I'd lean towards a wiring problem as it  happens when in a left turn (suspension geometry may be pulling on the sensor wiring, causing it to open or short).
  • 2 years later...
Weird issues with brakes on 2013 Ford Edge.  started with no brake pedal.  Old school thought master cylinder, also had booster leak so both replaced. More troubleshooting found ABS module bad.  Now after driving for about 30min feels like front left wheel locks up and have to turn vehicle off 5 min it releases and is fine for the rest of the hour trip.  on the way home an hour in happens again get code
Code: C0044 - Brake Pressure Sensor 'A'
Additional Fault Symptom (:28):
 - Signal Bias Level Out Of Range/Zero Adjustment Failure
Status (-68):
 - Previously Set DTC - Not Present at Time of Request
 - Malfunction Indicator Lamp is Off for this DTC
 - Test not complete
Module: Antilock braking system
 Freeze Frame  #1:
-EVENT_TIME: 377763044 s (Wed Apr 02 16:44:58 2025) - Event time
-POWER_MODE: Running  - Power Mode Status
-ABS: Inactive  - ABS
-AYC: Inactive  - AYC
-BTCS: Inactive  - BTCS -201D
-HDC: Inactive  - HDC
-RSC: Inactive  - RSC
-BTC: Inactive  - BTC
-VAC_BST_ST: Inactive  - Active Vacuum Booster State
-BST_REL_SW: Inactive  - Booster Release Switch State
-HYD_PMP_ST: Inactive  - Hydraulic Pump State
-ECU_POWER_SUPPLY: 13.5 V - ECU Power Supply Voltage
-VSS: 5.6 mph - Vehicle Speed
also
Code: P193C - Steering Wheel Angle Signal
Status (-6C):
 - DTC Maturing - Intermittent at Time of Request
 - Test not complete
Module: Powertrain Control Module
did the PCM key on engine off on demand self-test and PCM Key ON Engine running tests it didn't find any faults.
I see in list it says GO to Pinpoint Test C. Can you provide?  About to just sell this thing to lowest bidder lol this has been so frustrating.
Welcome to the Forum @Todd Turner!
Your described repair efforts indicate this question may be unnecessary, but since you don't mention performing a Programmable Module Installation (PMI) procedure:
When the ABS Module was replaced, did you configure the new ABS Module using the As-Built values contained in the ABS Module you removed?
Also, when the brake lock-up symptom occurs, are you hearing the ABS pump activating?
image.png.6dcc7e4c2d44dd765540ca2cd199c543.pngimage.png.529e6b47b4fac528c6b62d61db6d5991.png
Relevant sections from the 2013 Edge Workshop Manual and Wiring Resource are attached below as PDF documents...
Good Luck!
Brake Pedal and Bracket - Removal and Installation - 2013 Edge Workshop Manual.pdf BRAKE PEDAL POSITION (BPP) SWITCH - Connector C2064 Pinout Diagram - 2013 Edge.pdf BRAKE PEDAL POSITION (BPP) SWITCH - Connector C2064 Location - 2013 Edge.pdf BRAKE PEDAL POSITION (BPP) SWITCH - Power Distribution Wiring Diagram - 2013 Edge.pdf Stoplamp Switch - Removal and Installation - 2013 Edge Workshop Manual.pdf Component Tests - Brke System Diagnosis and Testing - 2013 Edge Workshop Manual.pdf Hydraulic Control Unit (HCU) - Removal and Installation - 2013 Edge Workshop Manual.pdf Pinpoint Test C - DTCs C0044.28, C0044.49 and C0044.64 - Diagnosis and Testing - 2013 Edge Workshop Manual.pdf Wheel Speed Sensor — Front - Removal and Installation - 2013 Edge Workshop Manual.pdf
  • Thanks 1
