126k not sure of previous maintenance done
Lanfe1n
Hi all.
I recently purchased a 2013 edge sport with 126k on the clock. The dealership did not have all the service history. I am unsure IF or when the last time the transmission fluid or PTU was changed. Should I be afraid to have the transmission fluid changed at this point? The PTU will need to be serviced for sure.
Thanks in advance!
29 minutes ago, 1004ron said:
Yes, if you don't have the service history then treat it as if every routine service item is overdue, engine oil & filter, air filter, cabin filter, spark plugs, trans fluid, PTU, ........etc.
Thanks! I should have been more clear. I’m worried about the debate on changing the transmission fluid if it has never been changed before. I have changed everything else and next one line is transmission and PTU.  Since I’m not sure if the transmission fluid has been changed could it cause any damage at this point?
