keiser Posted October 12, 2022 Report Share Posted October 12, 2022 I just bought a 2014 Edge. The passenger seat seems very low compared to the how I have adjusted the driver's seat. I think the passenger seat is not adjustable. What is the best method to raise the seat? Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted October 12, 2022 Report Share Posted October 12, 2022 (edited) I've seen where people used a lay-flat 2x4's with longer bolts. Raised it 1-1/2". Or kits designed specifically to raise a seat 0.25" to 1.5" https://a.co/d/6zznPYl If you need 2-3", this may work. https://www.tanksinc.com/index.cfm/page/ptype=product/product_id=750/mode=prod/prd750.htm?gclid=Cj0KCQjwy5maBhDdARIsAMxrkw26vP9Pjh7JVbf0PRbm7QgQDfKZ8wD1k5YgwT5nh8myEPIJcIGYG1kaAltREALw_wcB Also, to get 4", you could consider an adult booster seat. (Drop it in and .... done). https://a.co/d/jc8KHV4 If the seat belt is tight with a raised seat, you can get 6" seat belt extention from your Ford dealer. Free, just have to ask. (Made for larger sized people who have trouble with fitting into a standard seat belt). Make certain you ask (at parts counter) for a front seat adaptor as there's a difference between the front belt connectors and the rear seats. Edited October 13, 2022 by enigma-2 Quote Link to comment Share on other sites More sharing options...
keiser Posted October 13, 2022 Author Report Share Posted October 13, 2022 Excellent ideas. Thank you! Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 13, 2022 Report Share Posted October 13, 2022 (edited) https://www.mustang6g.com/forums/threads/need-to-level-out-the-front-drivers-seat.116469/#post-2448490 That is how I raised and leveled the seats in my wife's Mustang, and expect it should work for the Edge. Edit: keep in mind that you need two holes - one for the bolt and another for the dowel pin, so you'll need to drill a hole in the ones above in the Amazon link. Edited October 13, 2022 by 1004ron Quote Link to comment Share on other sites More sharing options...
