2013 valve cover gasket replacement
Philliphalljr
Hello! Got my daughter a 2013 limited, after some time a rod came through the block…put in a replacement with less miles on it, but our mechanic didn’t look it over for me…I was out of town…anyway, he put it in, it ran and I picked it up. Heater didn’t work, and now I am seeing oil from the valve cover. So…fixed the heat issue this weekend, new gate hose, thermostat, and temp sensor, and made sure air was out of the system. Now we have heat. Next up is the valve cover gasket. I have searched for a write up on it with no luck. Has anyone attempted it, or should I by a Haynes manual and knock it out? Also, will be looking for a new mechanic for when I am out of town again or can’t get to whatever happens!
thanks all!
Edited by Philliphalljr
Relevant sections from the 2013 Edge Workshop Manual presented below as PDF download links to guide your efforts:
Valve Cover - 2.0L EcoBoost - In-Vehicle Repair - 2013 Edge Workshop Manual.pdf , which includes these two images in reduced format, enlarged here for clarity...
Loosen-Install the 4 retainers and remove-install the underbody shield - Illustration - 2013 Edge Workshop Manual
1234529761_Loosen-Installthe4retainersandremove-installtheunderbodyshield-Illustration-2013EdgeWorkshopManual.jpg.4dc83712352ba3d8f7b3c4a9c8c157b9.jpg
Disconnect-Connect the FRP sensor, the MAP sensor and fuel charge harness electrical connectors - Illustration - 2013 Edge Workshop Manual
2128593562_Disconnect-ConnecttheFRPsensortheMAPsensorandfuelchargeharnesselectricalconnectors-Illustration-2013EdgeWorkshopManual.jpg.d1ef9e7482e0ae3f54301b4ad5286f28.jpg
Intake Air System Components — Exploded View - 2.0L EcoBoost - Removal and Installation - 2013 Edge Workshop Manual.pdf
Ignition Coil-On-Plug - Removal And Installation - 2013 Edge Workshop Manual.pdf
Quick Connect Coupling - General Procedures - 2013 Edge Workshop Manual.pdf
Good luck!
  • 1 year later...
On 10/3/2022 at 8:12 PM, Philliphalljr said:
So…Chilton manuals has an online library…who knew…found it there, but would love to hear from anyone that has done it. Are there any gotchas or anything else to do while I am there? Definitely going to change plugs and probably coil packs also…
I bought the online version, and it sucks.  Wouldn't recommend it.
On 11/12/2023 at 1:07 PM, DIY405_New said:
My valve cover is not wanting to lift up from the block on the left side (solenoid side).  All of the valve cover screws are loose, but this thing isn't budging.  What am I doing wrong?
Update: Solenoid seals were the reason the cover wouldn't come off.  The ripped when the valve cover was lifted up using a pry bar.
  • Thanks 1
