Appropriate oil filter for 2019 Edge
ZeroPlus
A 2009 Edge with the 3.5L engine had a production shift mid -January of the 2019 production run.  Prior to 1-16-09, it called for a FL400 oil filter.  After that date, it shifted to a FL500 (Motocraft).  The thread pitches on these 2 filters are different - FL400 is standard and the FL500 is metric - they should not be interchangeable.  The dealer said the model I had was the FL500 group, but then put on a Purolator TL20195 oil filter, which is the equivalent of the Motocraft FL400.  The insert in the manual says FL400 - SB12 or FL500, which is confusing, given the different thread pitches on the filter base.  I would have thought the threads on the oil filter mounting plate would be damaged with the wrong filter  - how can 2 different thread pitches be applicable?
Edited by ZeroPlus
