rear brake pads to small
Audrazas
Hi. Help needed. Does anyone know why the rear brake pads are not suitable for my ford? according to the codes, they should be good, but it seems that they are too small and should be wider. My edge is 2011 fwd 3.5l sel. Maybe anyone know what is correct code for wider pads suitable for my edge? Thank you.
I got these https://www.autodoc.lt/trw/2193000 and below you can see OEM codes. And after checking on this page https://shopparts.i25ford.com/oem-parts/ford-pad-brake-eu2z2v200e?c=Zz1icmFrZXMmcz1yZWFyLWJyYWtlcyZsPTExJm49QXNzZW1ibGllcyBQYWdlJmE9Zm9yZCZvPWVkZ2UmeT0yMDExJnQ9c2VsJmU9My01bC12Ni1nYXM%3D shows that they replaces with these codes. So I have made a mistake  somewhere. It's hard when you have the only edge like mine in whole country :)
