radicalfury Posted September 5, 2022 Report Share Posted September 5, 2022 I've had this issue since the beginning of time and dealer has not figured it out or done anything about it. It happens especially when hot out side , AC on. They tried the glue and reseal method in the TSB but no fix. I'm thinking it has something to do with the PTU or trans, but they say they cant replace the PTU unless its leaking. (or Cat?) Any help would be apricated ! Quote Link to comment Share on other sites More sharing options...
1004ron Posted September 5, 2022 Report Share Posted September 5, 2022 Is it a rotten egg sulfur smell - if so that happens when unburnt fuel get into the CAT. What TSB are you referring to? Quote Link to comment Share on other sites More sharing options...
radicalfury Posted September 6, 2022 Author Report Share Posted September 6, 2022 (edited) Yes Rotten egg sulfur smell fills the cab under hard acceleration on hot days.. They did this tsb: TSB 14-0201 EXHAUST SULFUR ODOR AFTER HARD ACCELERATION – CLIMATE CONTROL IN RECIRCULATION MODE ONLY Publication Date: October 28, 2014 FORD: 2011-2014 Edge LINCOLN: 2011-2015 MKX I printed it and they did it but it didnt change anything. The vehicle runs good though other then this. Edited September 6, 2022 by radicalfury Quote Link to comment Share on other sites More sharing options...
omar302 Posted September 6, 2022 Report Share Posted September 6, 2022 That TSB is for the older generation Edge. There is a newer one for 2015+ models (TSB 18-2057 - link). To test if this is really you issue, run the A/C in outside air mode (recirculate off). Quote Link to comment Share on other sites More sharing options...
radicalfury Posted September 6, 2022 Author Report Share Posted September 6, 2022 i was incorrect , that was the TSB they used. still no change. Quote Link to comment Share on other sites More sharing options...
radicalfury Posted September 8, 2022 Author Report Share Posted September 8, 2022 any other help would be apricated.! Quote Link to comment Share on other sites More sharing options...
