fuel pump replaced twice
Jaimeduardo7
My problem started in april 2022. I got stuck in the middle of nowhere because the bolts ceased and fuel pump was moving because of the vibration (bolts ceased and the holes where bolts fit were also worn out so new bolts did not solve the problem). I had to buy a new fuel pump. It worked for 3 months and these recent days I had the same problem again: bolts ceased therefore fuel pump is moving when the engine starts but engine turns off after couple of seconds because fuel pump is not transfering liquid from the fuel tank to the fuel injector of the internal combustion engine. It is a 2019 Ford Edge titanium.
For better reference, attached is a short video of fuel pump shaking.
Has any of you experienced this same problem or know how to solve it?
  • 1004ron changed the title to Fuel Pump Problem
My problem started in april 2022. I got stuck in the middle of nowhere because the bolts ceased therefore fuel pump was moving because of the vibration (bolts ceased and the holes where bolts fit were also worn out so new bolts did not solve the problem). I had to buy a new fuel pump. 4 months months later I had the same problem again: bolts ceased therefore fuel pump is moving when the engine starts but engine turns off after couple of seconds because fuel pump is not transfering liquid from the fuel tank to the fuel injector of the internal combustion engine. It is a 2019 Ford Edge titanium.
