Haz Posted August 26, 2022 Report Share Posted August 26, 2022 SSM 51055 - Adding/Removing Features Using Programmable Parameters Due To Vehicle Modifications Ford and Lincoln vehicle owners may request modifications to their vehicle such as enabling daytime running lamps (DRL), adding navigation, changing tire/axle sizes, and/or adding trailer brake control modules. A list of programmable parameters that are available for alteration is shown in Workshop Manual (WSM), Section 418-01A > Module Configuration. Parameters available for alteration will vary by model and model year. If the desired parameter is not listed in the right column of the Module Configuration and Parameter Chart, alteration of that parameter is not supported by Ford Motor Company. A list of supported parts that can be added to the vehicle is available at accessories.ford.com. Adding/removing accessories and/or programming vehicle features is not warrantable. 2 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted August 27, 2022 Author Report Share Posted August 27, 2022 To supplement this Special Service Message, below are Module Configuration and Parameter Charts for Model Year 2007 through 2022 Edge-MKX/Nautilus... 2007 Edge-MKX Module Name Reprogram/ Flash Capable Requires PMI Requires Adaptive Learning Requires Calibration Available Programmable Parameters 4X4 control module Yes No No No None ACM Yes Yes No No None ABS module Yes Yes No IVD initialization None DCSM Yes Yes No No None DSM Yes Yes No No Easy entry/exit DSP module Yes Yes No No None IC Yes Yes No No Belt-Minder® enable/disable Overspeed warning Transit mode enable/disable Headlamp control module (HCM) Yes No No No None Heating ventilation air conditioning (HVAC) module Yes No No No None Occupant classification system module (OCSM) Yes No No OCS re-zero None PAM No Yes No No None Liftgate/trunk module (LTM) Yes No No No None PCM Yes Yes Yes No Axle ratio Tire size Speed control enable/disable RCM Yes Yes No No Belt-Minder® enable/disable RETM Yes Yes No No Language English/ Spanish/French SDARS module enable/disable SDARS module Yes Yes No No None SJB Yes Yes No Tire pressure monitoring system (TPMS) sensor training Autolock and auto un-lock mode Daytime running lamp (DRL) enable/disable Perimeter lighting mode Stoplamp outage enable/disable Steering angle sensor module (SASM) Yes No No No None 2008 Edge-MKX Module Name Reprogram/ Flash Capable Requires PMI Requires Adaptive Learning Requires Calibration Available Programmable Parameters ABS module Yes Yes No IVD initialization None APIM Yes Yes No No None ACM Yes Yes No No Phone module DSP module Yes Yes No No None DSM Yes Yes No No Easy entry/exit DCSM Yes Yes No No None Headlamp control module (HCM) Yes No No No None HVAC module Yes No No No None IC Yes Yes No No Belt-Minder® Overspeed warning Transit mode Liftgate/trunk module (LTM) Yes No No No None Occupant classification system module (OCSM) Yes No No OCS re-zero None PAM No Yes No No None PCM Yes Yes Yes No Axle ratio Tire size Speed control present RETM Yes Yes No No Language English/ Spanish/French SDARS RCM Yes Yes No No Driver seat Belt-Minder® Passenger seat Belt-Minder® SDARS module Yes Yes No No None SJB Yes Yes No Tire pressure monitoring system (TPMS) sensor training Autolocks Auto un-locking Daytime running lamps (DRL) Perimeter lighting mode Stoplamp outage enable/disable Steering angle sensor module (SASM) Yes No No No None 4X4 control module Yes No No No None 2009 Edge-MKX Module Module Address Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters 4X4 control module 761 No Yes No None ABS module 760 Yes Yes IVD initialization None ACM 727 Yes Yes No Phone module (except navigation) Reverse park aid APIM (navigation only) Destination (navigation only) SDARS module (navigation only) Tuner region (navigation only) APIM 7D0 Yes Yes No None Audio DSP module 783 Yes Yes No None DCSM 776 Yes Yes No None DSM 744 Yes Yes No Easy entry/exit Headlamp Control Module (HCM) 734 No Yes No None HVAC module 733 No Yes No None IC 720 Yes Yes No Belt-Minder® Overspeed warning Transit mode Liftgate/Trunk Module (LTM) 775 No Yes No None Occupant Classification System Module (OCSM) 765 No Yes OCS re-zero None PAM 736 Yes No No None PCM 7E0 Yes Yes Adaptive airflow Idle speed Refueling event Fuel trim Axle ratio Tire size Speed control present RCM 737 Yes Yes No Driver seat Belt-Minder® Passenger seat Belt-Minder® SDARS module 782 Yes Yes No None SJB 726 Yes Yes Tire Pressure Monitoring System (TPMS) sensor training Autolocks Daytime Running Lamps (DRL) Global open Perimeter lighting mode Stop lamp outage enable/disable Tire placard pressure Steering Angle Sensor Module (SASM) 797 No Yes No None 2010 Edge-MKX Module Module Address Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters 4X4 control module 761 No Yes No None ABS module 760 Yes Yes IVD initialization None Accessory Protocol Interface Module (APIM) 7D0 Yes Yes No Stereo in pass-through Audio Front Control Module (ACM) 727 Yes Yes No Phone module (except navigation) Reverse park aid APIM (navigation only) Destination (navigation only) SDARS module (navigation only) Tuner region (navigation only) Audio Digital Signal Processing (DSP) module 783 Yes Yes No None Driver Seat Module (DSM) 744 Yes Yes No Easy entry/exit Dual Climate Controlled Seat Module (DCSM) 776 Yes Yes No None Global Positioning System Module (GPSM) 701 No No No None Headlamp Control Module (HCM) 734 No Yes No None HVAC module 733 No Yes No None Instrument Cluster (IC) 720 Yes Yes No Belt-Minder® Overspeed warning Transit mode Liftgate/Trunk Module (LTM) 775 No Yes No None Occupant Classification System Module (OCSM) 765 No Yes OCS re-zero None Parking Aid Module (PAM) 736 Yes No No None PCM 7E0 Yes Yes Adaptive airflow Idle speed Refueling event Fuel trim Axle ratio Tire size Speed control present Restraints Control Module (RCM) 737 Yes Yes No Driver seat Belt-Minder® Passenger seat Belt-Minder® Satellite Digital Audio Receiver System (SDARS) module 782 Yes Yes No None Smart Junction Box (SJB) 726 Yes Yes Tire Pressure Monitoring System (TPMS) sensor training Autolock Auto-unlock Daytime Running Lamps (DRL) Global open Perimeter lighting mode Stop lamp outage enable/disable Tire placard pressure Steering Angle Sensor Module (SASM) 797 No Yes No None 2011 Edge-MKX Module Name Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters Accessory Protocol Interface Module (APIM) Yes Yes No Clock display ABS module Yes Yes IVD initialization Tire size (must match BCM ) Audio Front Control Module (ACM) Yes Yes No None Audio Digital Signal Processing (DSP) module Yes Yes No None Body Control Module (BCM) Yes Yes No Axle ratio Courtesy lamp dimming type Police dark car feature Smart unlocking Stop and turn lamp outage configuration Tire placard pressure Tire size (must match ABS module) Daytime running lamps Cruise-Control Module (C-CM) Yes Yes No None Driver Seat Module (DSM) Yes Yes No None Dual Climate Controlled Seat Module (DCSM) Yes Yes No None Front Lighting Control Module (FLM) No Yes No None Front Controls Interface Module (FCIM) No Yes No None Front Control/Display Interface Module (FCDIM) Yes Yes No None Global Positioning System Module (GPSM) No Yes No None Heated Steering Wheel Module (HSWM) Yes Yes No None Headlamp Control Module (HCM) No Yes No None Head Up Display (HUD) module No Yes No None HVAC module Yes Yes No None Instrument Panel Cluster (IPC) Yes Yes No Belt-Minder® English/Metric Language Rear fog lamps Rear reverse gear wipe Liftgate/Trunk Module (LTM) No Yes No None Occupant Classification System Module (OCSM) No Yes OCS re-zero None Parking Aid Module (PAM) No Yes No None PCM Yes Yes Adaptive airflow Axle ratio Idle speed Refueling event Fuel trim present Tire size None Remote Function Actuator (RFA) module Yes Yes No Intelligent Access (IA) Restraints Control Module (RCM) Yes Yes No Driver Belt-Minder® Passenger Belt-Minder® Steering Column Control Module (SCCM) Yes Yes No None Side Obstacle Detection Control Module - Left (SOD-L) Yes Yes No On/Off Side Obstacle Detection Control Module - Right (SOD-R) Yes Yes No On/Off Tire Pressure Monitor (TPM) No Yes No None 2012 Edge-MKX Module Name Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters Accessory Protocol Interface Module (APIM) Yes Yes No Clock display Navigation application ABS module Yes Yes IVD initialization Tire size (must match BCM ) Audio Front Control Module (ACM) Yes Yes No MP3 CD text conversion Audio Digital Signal Processing (DSP) module Yes Yes No None Body Control Module (BCM) Yes Yes No Axle ratio Courtesy lamp dimming type Daytime Running Lamps (DRL) feature Daytime Running Lamps (DRL) type Police dark car feature Smart unlocking Stop and turn lamp outage configuration Tire placard pressure Tire size (must match ABS module) Cruise-Control Module (C-CM) Yes Yes No None Driver Seat Module (DSM) Yes Yes No None Dual Climate Controlled Seat Module (DCSM) Yes Yes No None Front Lighting Control Module (FLM) No Yes No None Front Controls Interface Module (FCIM) No Yes No None Front Control/Display Interface Module (FCDIM) Yes Yes No Date format Global Positioning System Module (GPSM) Yes Yes No None Heated Steering Wheel Module (HSWM) Yes Yes No None Headlamp Control Module (HCM) No Yes No None Head Up Display (HUD) module No Yes No None HVAC module Yes Yes No None Instrument Panel Cluster (IPC) Yes Yes No Back up chime Belt-Minder® Courtesy wipe after wash English/Metric Gallon display type Navigation Rear fog lamps Rear reverse gear wipe Liftgate/Trunk Module (LTM) No Yes No None Occupant Classification System Module (OCSM) No Yes OCS re-zero None Parking Aid Module (PAM) No Yes No None PCM Yes Yes Adaptive airflow Axle ratio Idle speed Refueling event Fuel trim present Tire size None Remote Function Actuator (RFA) module Yes Yes No Autolock Autounlock One/two stage unlock Intelligent Access (IA) Restraints Control Module (RCM) Yes Yes No Driver Belt-Minder® Passenger Belt-Minder® Steering Column Control Module (SCCM) Yes Yes No None Side Obstacle Detection Control Module - Left (SOD-L) Yes Yes No Blind Spot Information System (BLIS®) Cross Traffic Alert (CTA) Side Obstacle Detection Control Module - Right (SOD-R) Yes Yes No BLIS® CTA Tire Pressure Monitor (TPM) (also known as the Radio Transceiver Module [RTM]) No Yes No None Transmission Control Module (TCM) Yes Yes No None 2013 Edge-MKX Module Name Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters Accessory Protocol Interface Module (APIM) Yes Yes No Clock display Navigation application ABS module Yes Yes IVD initialization Tire size (must match BCM ) Audio Front Control Module (ACM) Yes Yes No MP3 CD text conversion Audio Digital Signal Processing (DSP) module Yes Yes No None Body Control Module (BCM) Yes Yes No Axle ratio Courtesy lamp dimming type Daytime Running Lamps (DRL) feature Daytime Running Lamps (DRL) type Police dark car feature Smart unlocking Stop and turn lamp outage configuration Tire placard pressure Tire size (must match ABS module) Cruise-Control Module (C-CM) Yes Yes No None Driver Seat Module (DSM) Yes Yes No None Dual Climate Controlled Seat Module (DCSM) Yes Yes No None Front Lighting Control Module (FLM) No Yes No None Front Controls Interface Module (FCIM) No Yes No None Front Control/Display Interface Module (FCDIM) Yes Yes No Date format Global Positioning System Module (GPSM) Yes Yes No None Heated Steering Wheel Module (HSWM) Yes Yes No None Headlamp Control Module (HCM) No Yes No None Head Up Display (HUD) module No Yes No None HVAC module Yes Yes No None Instrument Panel Cluster (IPC) Yes Yes No Back up chime Belt-Minder® Courtesy wipe after wash English/Metric Gallon display type Navigation Rear fog lamps Rear reverse gear wipe Liftgate/Trunk Module (LTM) No Yes No None Occupant Classification System Module (OCSM) No Yes OCS re-zero None Parking Aid Module (PAM) No Yes No None PCM Yes Yes Adaptive airflow Axle ratio Idle speed Refueling event Fuel trim present Tire size None Remote Function Actuator (RFA) module Yes Yes No Autolock Autounlock One/two stage unlock Intelligent Access (IA) Restraints Control Module (RCM) Yes Yes No Driver Belt-Minder® Passenger Belt-Minder® Steering Column Control Module (SCCM) Yes Yes No None Side Obstacle Detection Control Module - Left (SOD-L) Yes Yes No Blind Spot Information System (BLIS®) Cross Traffic Alert (CTA) Side Obstacle Detection Control Module - Right (SOD-R) Yes Yes No BLIS® CTA Tire Pressure Monitor (TPM) (also known as the Radio Transceiver Module [RTM]) No Yes No None Transmission Control Module (TCM) Yes Yes No None 2014 Edge-MKX Module Name Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters Accessory Protocol Interface Module (APIM) Yes Yes No Clock display Navigation application ABS module Yes Yes IVD initialization Tire size (must match BCM ) Audio Front Control Module (ACM) Yes Yes No MP3 CD text conversion Audio Digital Signal Processing (DSP) module Yes Yes No None Body Control Module (BCM) Yes Yes No Axle ratio Courtesy lamp dimming type Daytime Running Lamps (DRL) feature Daytime Running Lamps (DRL) type Police dark car feature Smart unlocking Stop and turn lamp outage configuration Tire placard pressure Tire size (must match ABS module) Cruise-Control Module (C-CM) Yes Yes No None Driver Seat Module (DSM) Yes Yes No None Dual Climate Controlled Seat Module (DCSM) Yes Yes No None Front Lighting Control Module (FLM) No Yes No None Front Controls Interface Module (FCIM) No Yes No None Front Control/Display Interface Module (FCDIM) Yes Yes No Date format Global Positioning System Module (GPSM) Yes Yes No None Heated Steering Wheel Module (HSWM) Yes Yes No None Headlamp Control Module (HCM) No Yes No None Head Up Display (HUD) module No Yes No None HVAC module Yes Yes No None Instrument Panel Cluster (IPC) Yes Yes No Back up chime Belt-Minder® Courtesy wipe after wash English/Metric Gallon display type Navigation Rear fog lamps Rear reverse gear wipe Liftgate/Trunk Module (LTM) No Yes No None Occupant Classification System Module (OCSM) No Yes OCS re-zero None Parking Aid Module (PAM) No Yes No None PCM Yes Yes Adaptive airflow Axle ratio Idle speed Refueling event Fuel trim present Tire size None Remote Function Actuator (RFA) module Yes Yes No Autolock Autounlock One/two stage unlock Intelligent Access (IA) Restraints Control Module (RCM) Yes Yes No Driver Belt-Minder® Passenger Belt-Minder® Steering Column Control Module (SCCM) Yes Yes No None Side Obstacle Detection Control Module - Left (SOD-L) Yes Yes No Blind Spot Information System (BLIS®) Cross Traffic Alert (CTA) Side Obstacle Detection Control Module - Right (SOD-R) Yes Yes No BLIS® CTA Tire Pressure Monitor (TPM) (also known as the Radio Transceiver Module [RTM]) No Yes No None Transmission Control Module (TCM) Yes Yes No None 2015 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCDIM 7A5 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM 701 Yes Yes No None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SCCM 724 Yes Yes No None TRM 791 Yes Yes No None 2015 MKX Module Name Requires PMI Reprogram/ Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters Accessory Protocol Interface Module (APIM) Yes Yes No Clock display Navigation application ABS module Yes Yes IVD initialization Tire size (must match BCM ) Audio Front Control Module (ACM) Yes Yes No MP3 CD text conversion Audio Digital Signal Processing (DSP) module Yes Yes No None Body Control Module (BCM) Yes Yes No Axle ratio Courtesy lamp dimming type Daytime Running Lamps (DRL) feature Daytime Running Lamps (DRL) type Police dark car feature Smart unlocking Stop and turn lamp outage configuration Tire placard pressure Tire size (must match ABS module) Cruise-Control Module (C-CM) Yes Yes No None Driver Seat Module (DSM) Yes Yes No None Dual Climate Controlled Seat Module (DCSM) Yes Yes No None Front Lighting Control Module (FLM) No Yes No None Front Controls Interface Module (FCIM) No Yes No None Front Control/Display Interface Module (FCDIM) Yes Yes No Date format Global Positioning System Module (GPSM) Yes Yes No None Heated Steering Wheel Module (HSWM) Yes Yes No None Headlamp Control Module (HCM) No Yes No None Head Up Display (HUD) module No Yes No None HVAC module Yes Yes No None Instrument Panel Cluster (IPC) Yes Yes No Back up chime Belt-Minder® Courtesy wipe after wash English/Metric Gallon display type Navigation Rear fog lamps Rear reverse gear wipe Liftgate/Trunk Module (LTM) No Yes No None Occupant Classification System Module (OCSM) No Yes OCS re-zero None Parking Aid Module (PAM) No Yes No None PCM Yes Yes Adaptive airflow Axle ratio Idle speed Refueling event Fuel trim present Tire size None Remote Function Actuator (RFA) module Yes Yes No Autolock Autounlock One/two stage unlock Intelligent Access (IA) Restraints Control Module (RCM) Yes Yes No Driver Belt-Minder® Passenger Belt-Minder® Steering Column Control Module (SCCM) Yes Yes No None Side Obstacle Detection Control Module - Left (SOD-L) Yes Yes No Blind Spot Information System (BLIS®) Cross Traffic Alert (CTA) Side Obstacle Detection Control Module - Right (SOD-R) Yes Yes No BLIS® CTA Tire Pressure Monitor (TPM) (also known as the Radio Transceiver Module [RTM]) No Yes No None Transmission Control Module (TCM) Yes Yes No None 2016 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCDIM 7A5 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM (without touchscreen) 701 Yes Yes No None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SCCM 724 Yes Yes No None TRM 791 Yes Yes No None 2016 MKX Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM (if equipped with SYNC 2) 701 Yes Yes No None HCM 734 Yes No LED Lamp Driver Module Initialization None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None Passenger front seat module (SCMB) 7A3 Yes No No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RACM 774 No No No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SCMG 712 Yes No No None SCMH 713 Yes No No None SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure Vehicle tune selector Wheel/tire diameter SCCM 724 Yes Yes No None TCU 754 Yes No No None TRM 791 Yes Yes No None VDM 721 Yes Yes Ride height calibration None 2017 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BECMB 723 Yes No No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCDIM 7A5 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM (without touchscreen) 701 Yes Yes No None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SCCM 724 Yes Yes No None TRM 791 Yes Yes No None 2017 MKX Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BECMB 723 Yes No No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None HCM 734 Yes No LED Lamp Driver Module Initialization None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None Passenger front seat module (SCMB) 7A3 Yes No No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RACM 774 No No No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SCMG 712 Yes No No None SCMH 713 Yes No No None SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure Vehicle tune selector SCCM 724 Yes Yes No None TCU 754 Yes No No None TRM 791 Yes Yes No None VDM 721 Yes Yes Ride height calibration None 2018 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BECMB 723 Yes No No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Remote start enable/disable Perimeter alarm Tire pressure CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No None DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCDIM 7A5 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None GPSM (without touchscreen) 701 Yes Yes No None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Daytime running lamps control function Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SCCM 724 Yes Yes No None TRM 791 Yes Yes No None 2018 MKX Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters APIM 7D0 Yes Yes No None ABS module 760 Yes Yes IVD initialization EPB apply and release Trailer sway assist ACM 727 Yes Yes No None BECMB 723 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Autolock 1-5 DRL by autolamps initial validation DRL by autolamps 1-5 Front/rear tire placard (pressure) Perimeter alarm (except Japan) Remote start enable/disable CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DSP 783 Yes Yes No None DACMC (integrated with ACM ) 7D5 Yes Yes No ANC functionality ESE functionality DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None SCME 776 Yes Yes No None FCIM 7A7 Yes Yes No None GWM 716 Yes Yes No None HCM 734 Yes No LED Lamp Driver Module Initialization None HUD module 7B2 No No No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No Autofold mirrors DRL control function Neutral tow Remote start feature Remote start - climate settings Driver seat Passenger seat Rear defrost Steering wheel IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None SCMB 7A3 Yes No No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RTM 751 Yes Yes No None RACM 774 No No No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SCMG 712 Yes No No None SCMH 713 Yes No No None SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure Vehicle tune selector SCCM 724 Yes Yes No Rear wiper reverse wipe enable/disable TCU 754 Yes No No None TRM 791 Yes Yes No None VDM 721 Yes Yes Height sensor calibration None 2019 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes IVD initialization EPB apply and release None ACM 727 Yes Yes No None AHCM 7E3 Yes Yes No None APIM 7D0 Yes Yes No None AWD module 703 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Autolock enable DRL by autolamps Remote start enable/disable Perimeter alarm Tire pressure BECMB 723 Yes Yes No None CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No ANC ESE DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None DSP 783 Yes Yes No None FCIM 7A7 Yes Yes No None GSM 732 Yes Yes No None GWM 716 Yes Yes No None HCM 734 Yes Yes No None HSWM 714 Yes Yes No None IPC 720 Yes Yes No None IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RCM 737 Yes Yes No None RGTM 775 Yes Yes No None RTM 751 Yes Yes No None SASM 797 Yes Yes Adaptive steering wheel angle sensor trim adjustment None SCCM 724 Yes Yes No None SCME 776 Yes Yes No None SECM 7C5 Yes Yes Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SODL 7C4 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes Yes No BLIS/CTA enable/disable Blockage enable/disable TCU 754 Yes Yes No None TRM 791 Yes Yes No None WACM 725 Yes Yes No None 2019 Nautilus Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters ABS module 760 Yes Yes IVD initialization EPB apply and release None ACM 727 Yes Yes No None APIM 7D0 Yes Yes No None AWD module 703 Yes No No None BECMB 723 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Autolock 1-4 DRL by autolamps initial validation DRL by autolamps 1-5 Front/rear tire placard (pressure) Perimeter alarm Remote start enable/disable CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No ANC functionality ESE functionality DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes No No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes No No None DSP 783 Yes No No None FCIM 7A7 Yes Yes No None GSM 732 No No No None GWM 716 Yes No No None HCM 734 Yes No LED Lamp Driver Module Initialization None HSWM 714 Yes No No None IPC 720 Yes No No None IPMA 706 Yes No Camera calibration None IPMB 7B1 Yes No Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RACM 774 No No No None RCM 737 Yes No No None RGTM 775 Yes Yes No None RTM 751 Yes No No None SASM 797 Yes No Adaptive steering wheel angle sensor trim adjustment None SCCM 724 Yes No No None SCMB 7A3 Yes No No None SCME 776 Yes No No None SCMG 712 Yes No No None SCMH 713 Yes No No None SECM 7C5 Yes No Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SODL 7C4 Yes No No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes No No BLIS/CTA enable/disable Blockage enable/disable TCU 754 Yes No No None TRM 791 Yes No No None VDM 721 Yes Yes Height sensor calibration None WACM 725 Yes No No None 2020 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes IVD initialization EPB apply and release None ACM 727 Yes Yes No None AHCM 7E3 Yes No No None APIM 7D0 Yes No No None AWD module 703 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Autolock enable DRL by auto lamps Remote start enable/disable Perimeter alarm Tire pressure BECMB 723 Yes No No None CCM 764 Yes No Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No ANC ESE DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes No No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes No No None DSP 783 Yes No No None FCIM 7A7 Yes Yes No None GSM 732 No Yes No None GWM 716 Yes No No None HCM 734 Yes No No None HSWM 714 Yes No No None IPC 720 Yes No No None IPMA 706 Yes No Camera calibration None IPMB 7B1 Yes No Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PSCM 730 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None RCM 737 Yes No No None RGTM 775 Yes Yes No None RTM 751 Yes No No None SCCM 724 Yes No No None SCME 776 Yes No No None SODL 7C4 Yes No No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes No No BLIS/CTA enable/disable Blockage enable/disable TCU 754 Yes No No None TRM 791 Yes No No None WACM 725 Yes No No None 2020 Nautilus Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Progammable Parameters ABS module 760 Yes Yes IVD initialization EPB apply and release None ACM 727 Yes Yes No None APIM 7D0 Yes Yes No None AWD module 703 Yes No No None BECMB 723 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration Autolock 1-4 DRL by autolamps initial validation DRL by autolamps 1-5 Front/rear tire placard (pressure) Perimeter alarm Remote start enable/disable CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No ANC functionality ESE functionality DC / DC converter control module (Voltage Quality Module [VQM]) 746 Yes No No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes No No None DSP 783 Yes No No None FCIM 7A7 Yes Yes No None GSM 732 No No No None GWM 716 Yes No No None HCM 734 Yes No LED Lamp Driver Module Initialization None HSWM 714 Yes No No None IPC 720 Yes No No None IPMA 706 Yes No Camera calibration None IPMB 7B1 Yes No Camera calibration None OCSM 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RACM 774 No No No None RCM 737 Yes No No None RGTM 775 Yes Yes No None RTM 751 Yes No No None SASM 797 Yes No Adaptive steering wheel angle sensor trim adjustment None SCCM 724 Yes No No None SCMB 7A3 Yes No No None SCME 776 Yes No No None SCMG 712 Yes No No None SCMH 713 Yes No No None SECM 7C5 Yes No Adaptive steering wheel angle sensor trim adjustment Actuator trim procedure None SODL 7C4 Yes No No BLIS/CTA enable/disable Blockage enable/disable SODR 7C6 Yes No No BLIS/CTA enable/disable Blockage enable/disable TCU 754 Yes No No None TRM 791 Yes No No None VDM 721 Yes Yes Height sensor calibration None WACM 725 Yes No No None 2021 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes Brake system pressure bleeding EPB initialization ABS calibration ABS module bleed configuration ABS coil solenoid calibration None ACM 727 Yes Yes No None APIM 7D0 Yes Yes (diagnostic scan tool and USB flash drive) No None AWD module 703 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration None CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No Radio noise suppression DCDC (VQM) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None DSP 783 Yes Yes No None GSM 732 Yes Yes No None GWM 716 Yes Yes (diagnostic scan tool and USB flash drive) No None HCM 734 Yes Yes LED Lamp Driver Module Initialization None HSWM 714 Yes Yes No None HVAC module 733 Yes Yes No None IPC 720 Yes Yes No None IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCS module 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RCM 737 Yes Yes No None RGTM 775 Yes Yes No None RTM 751 Yes Yes No None SCCM 724 Yes Yes No None SCME 776 Yes Yes No None SODL 7C4 Yes Yes No None SODR 7C6 Yes Yes No None TCU 754 Yes Yes (diagnostic scan tool and USB flash drive) No None TRM 791 Yes Yes No None WACM 725 Yes Yes No None 2021 Nautilus Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes Integrated Vehicle Dynamics (IVD) initialization EPB apply and release None ACM 727 Yes Yes No None APIM 7D0 Yes Yes (diagnostic scan tool and USB flash drive) No None AWD module 703 Yes Yes No None BCM 726 Yes Yes PATS key programming (not using the diagnostic scan tool) PATS parameter reset CEI BMS reset If equipped with rear video parking aid, BCM LIN initialization TPMS training None CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No Radio noise suppression DCDC (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None DSP 783 Yes Yes No None FCIMB 7A0 Yes Yes No None GSM 732 No No No None GWM 716 Yes Yes (diagnostic scan tool and USB flash drive) No None HCM 734 Yes Yes LED Lamp Driver Module Initialization None HSWM 714 Yes Yes No None HVAC module 733 Yes Yes No None IPC 720 Yes Yes No None IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Front and rear camera calibration None OCS module 765 No No OCSM re-zero None PAM 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RCM 737 Yes Yes No None RFA module 731 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None RTM 751 Yes Yes No None SCCM 724 Yes Yes SCCM LIN configuration None SCMB 7A3 Yes Yes No None SCME 776 Yes Yes No None SCMG 712 Yes Yes No None SCMH 713 Yes Yes No None SODL 7C4 Yes Yes No None SODR 7C6 Yes Yes No None TCU 754 Yes Yes (diagnostic scan tool and USB flash drive) No None TRM 791 Yes Yes No None VDM 721 Yes Yes Height sensor calibration None WACM 725 Yes Yes No None 2022 Edge Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes Brake system pressure bleeding EPB initialization ABS calibration ABS module bleed configuration ABS coil solenoid calibration None ACM 727 Yes Yes No None APIM 7D0 Yes Yes (diagnostic scan tool and USB flash drive) No None AWD module 703 Yes Yes No None BCM 726 Yes Yes Ambient lighting calibration Rear view camera calibration None CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No Radio noise suppression DCDC (VQM) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None DSP 783 Yes Yes No None GSM 732 Yes Yes No None GWM 716 Yes Yes (diagnostic scan tool and USB flash drive) No None HCM 734 Yes Yes LED Lamp Driver Module Initialization None HSWM 714 Yes Yes No None HVAC module 733 Yes Yes No None IPC 720 Yes Yes No None IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Camera calibration None OCS module 765 No No OCSM re-zero None PAM (integrated with BCM ) 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RCM 737 Yes Yes No None RGTM 775 Yes Yes No None RTM 751 Yes Yes No None SCCM 724 Yes Yes No None SCME 776 Yes Yes No None SODL 7C4 Yes Yes No None SODR 7C6 Yes Yes No None TCU 754 Yes Yes (diagnostic scan tool and USB flash drive) No None TRM 791 Yes Yes No None WACM 725 Yes Yes No None 2022 Nautilus Module Name Module Address Programmable Module Installation (PMI) Available Reprogram/Flash Capable Requires Adaptive Learning or Calibration Available Programmable Parameters ABS module 760 Yes Yes Integrated Vehicle Dynamics (IVD) initialization EPB apply and release None ACM 727 Yes Yes No None APIM 7D0 Yes Yes (diagnostic scan tool and USB flash drive) No None AWD module 703 Yes Yes No None BCM 726 Yes Yes PATS key programming (not using the diagnostic scan tool) PATS parameter reset CEI BMS reset If equipped with rear video parking aid, BCM LIN initialization TPMS training None CCM 764 Yes Yes Radar horizontal and vertical alignment calibration None DACMC (integrated with ACM ) 7D5 Yes Yes No Radio noise suppression DCDC (Voltage Quality Module [VQM]) 746 Yes Yes No None DDM 740 Yes Yes Windows initialization None DSM 744 Yes Yes No None DSP 783 Yes Yes No None FCIMB 7A0 Yes Yes No None GSM 732 No No No None GWM 716 Yes Yes (diagnostic scan tool and USB flash drive) No None HCM 734 Yes Yes LED Lamp Driver Module Initialization None HSWM 714 Yes Yes No None HVAC module 733 Yes Yes No None IPC 720 Yes Yes No None IPMA 706 Yes Yes Camera calibration None IPMB 7B1 Yes Yes Front and rear camera calibration None OCS module 765 No No OCSM re-zero None PAM 736 Yes Yes No None PCM 7E0 Yes Yes Misfire Monitor Neutral Profile Correction procedure None PDM 741 Yes Yes Windows initialization None PSCM 730 Yes Yes No None RCM 737 Yes Yes No None RFA module 731 Yes Yes No None RGTM 775 Yes Yes No None RCM 737 Yes Yes No None RTM 751 Yes Yes No None SCCM 724 Yes Yes SCCM LIN configuration None SCMB 7A3 Yes Yes No None SCME 776 Yes Yes No None SCMG 712 Yes Yes No None SCMH 713 Yes Yes No None SODL 7C4 Yes Yes No None SODR 7C6 Yes Yes No None TCU 754 Yes Yes (diagnostic scan tool and USB flash drive) No None TRM 791 Yes Yes No None VDM 721 Yes Yes Height sensor calibration None WACM 725 Yes Yes No None Good luck! 2 1 Quote Link to comment Share on other sites More sharing options...
