Engine to replace
Portugalczyk
ford always changes a few things as model years roll by, but nothing that can't be overcome.
typically you have to use the sensors and flexplate that come with your 2013 engine instead of the more recent one. meaning if you get new sensors or flexplate, they should be a fit for your VIN number.
also some mounting bits may differ. again, reuse the 2013 bits for that perfect fit.
use motorcraft yellow coolant, or peak 10x/prestone 300k universals.
