ChrisW Posted August 18, 2022 Report Share Posted August 18, 2022 What size Allen key is required? Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 18, 2022 Report Share Posted August 18, 2022 (edited) Edited August 18, 2022 by 1004ron Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 20, 2022 Report Share Posted August 20, 2022 Well, as long as we're kicking a dead horse; (cheap but good enough for occasional use). https://hftools.com/app69546 Quote Link to comment Share on other sites More sharing options...
1004ron Posted August 20, 2022 Report Share Posted August 20, 2022 (edited) 1 hour ago, enigma-2 said: Well, as long as we're kicking a dead horse; (cheap but good enough for occasional use). https://hftools.com/app69546 There's one problem with that set - its missing the one that's needed for the brake calipers. I recommend a 1/2" drive for this application. 4mm, 5mm, 6mm, 7mm, 8mm, 10mm Edited August 20, 2022 by 1004ron Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted August 21, 2022 Report Share Posted August 21, 2022 7 hours ago, 1004ron said: There's one problem with that set - its missing the one that's needed for the brake calipers. I recommend a 1/2" drive for this application. 4mm, 5mm, 6mm, 7mm, 8mm, 10mm Sad part is the 1/2" drive set doesn't have the 11 mm either ? Quote Link to comment Share on other sites More sharing options...
JiminMI Posted December 5, 2023 Report Share Posted December 5, 2023 I recently replaced the front brake pads and rotors on my 2019 Edge SEL 2.0 Ecoboost. I found the 11mm Allen socket needed at a local NAPA store. Only about $3.50 including tax. It has a 3/8" drive. As a side note, it turns out you can replace the pads in the caliper without removing the pins that use the 11mm Allen socket. My calipers just slid off the pins. The socket had to be ordered by NAPA and came in after I had completed the job. My pads and rotors had issues with rust not allowing the pads to have full contact with the rotors. These were the original brakes at just over 100k miles. 1 Quote Link to comment Share on other sites More sharing options...
