Piston Rings for 2019 Edge, 2.0
Hello!
I need to order new pistons rings and I found on tascaparts that correct part number for my car is K2GZ-6148-A (indicated as Standard) and K2GZ-6148-B (indicated as 0.50mm o/s)
I tried to find out what the difference is and in some online stores they told me that the K2GZ-6148-A option was discontinued, others said that option A is standard, and option B is needed after cylinder repair. Not sure what to order.
Please help me figure it out. Maybe someone knows or can check with the dealer.
Thank you.
Edited by BaZZaD
update
Why do you need new piston rings?  You have to completely take apart the engine to replace them.
Standard would indicate factory bore size.  The other one indicated as .50mm O/S is oversized for when you have a catastrophic event and the cylinders need to be bored oversized to remove scratches or gouges.
