Haz Posted July 29, 2022 Report Share Posted July 29, 2022 (edited) SSM 50975 2017-2022 Various Ford And Lincoln Vehicles - Deep Sleep Mode Notification In FordPass® And/Or LincolnWay® Cell Phone Apps Some 2017-2022 Ford/Lincoln customers may experience a notification in the FordPass®/LincolnWay® app indicating Vehicle Has Entered Deep Sleep Mode. This occurs when the vehicle has not been started for 14 consecutive days, battery voltage is at/below 9.5 volts or the body control module (BCM) 12 volt battery state of charge (SOC) drops below 50%. A warning may also set if the telematic control unit (TCU) has received an over the air update. The TCU powers down all communication when in this mode and app features are disabled. Manually start the vehicle to wake if from mode. More information is located in the app under: Account > Help > search 'Deep Sleep' in the entry box. If the condition remains, check the BCM 12v SOC. If the SOC does not change after charging the battery or after BMS reset is performed, continue with normal battery and/or BMS sensor diagnostics. Edited February 29, 2024 by Haz 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted March 15, 2023 Author Report Share Posted March 15, 2023 Ford has developed a software update for the Telematics Control Unit (TCU) in 2020-2023 vehicles to avoid previously described Deep Sleep FordPass/LincolnWay notifications, per the following newly issued Special Service Message... SSM 51449 2020-2023 Various Vehicles - SYNC3 - Inaccurate Deep Sleep Notifications In FordPass/LincolnWay Some 2020-2023 Ford and Lincoln SYNC3 equipped vehicles may experience an inaccurate notification in the FordPass®/LincolnWay® app indicating Vehicle Has Entered Deep Sleep Mode. Vehicle Has Entered Deep Sleep Mode message is expected if the vehicle has not been started for 14 consecutive days, battery voltage is at/below 9.5 volts or the body control module (BCM) 12 volt battery state of charge (SoC) drops below 50%. If the vehicle is going into deep sleep outside these conditions, this may be due to the telematics control unit (TCU) software. To correct this condition, follow the Service Procedure to update the TCU to the latest software. For claiming, use causal part 14G229 and applicable labor operations in Section 10 of the Service Labor Time Standards (SLTS) Manual. 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 16, 2023 Author Report Share Posted June 16, 2023 Ford continues to inform Service technicians on Telematics Control Unit (TCU) software update to remedy inaccurate Deep Sleep notifications for SYNC 3 equipped 2020-2023 vehicles... 3 Quote Link to comment Share on other sites More sharing options...
Haz Posted February 29, 2024 Author Report Share Posted February 29, 2024 Supplemental information from the Edge Workshop Manual... 1 Quote Link to comment Share on other sites More sharing options...
