Kclonn Posted July 20, 2022 Author Report Share Posted July 20, 2022 Ok. The part arrived. Super easy install. Took me about 20 minutes including rounding up some parts. This did not come with screws so I ran to the auto parts store and got some #8 screws with washers. Be aware that the washers need to be bigger than the ones that came on the screws I bought, so be prepared for that. This is where the ends of the bracket attach. Remove nut on both ends. Now you just slide the front of the shield over the muffler and lift the floppy bumper enough to slide it in place on top of the bumper so the holes align. The tabs on the end of the shield go on the studs where you removed the nuts so screw those back on as seen below. Now just screw in the 4 screws you got and that is it. Simple. I am going to go back and look at the drawings because there is still a gap in the center that I don’t like. If I can’t find a part, I will make something. I don’t want sand and dirt collecting in there. The gap looks larger than it is because of the wide angle on the phone. It’s still too big for my taste. At least the bumper is no longer loose. 1 1 Quote Link to comment Share on other sites More sharing options...
Kclonn Posted July 21, 2022 Author Report Share Posted July 21, 2022 Just got notified from the dealer that they are ordering me the hood insulation as the vin showed it being an installed part. No charge. I’m getting there! 1 Quote Link to comment Share on other sites More sharing options...
Davidoo Posted July 21, 2022 Report Share Posted July 21, 2022 (edited) I have the rear bumper part and the hood insulator on order. Should both be in Friday. So, for the rear bumper part, you didn't have to take anything off to put this on? When you say you had to round up some screws, were they for the 4 attach points to the rear bumper cover at the bottom? It looks like for the two upper forward sides, you just took the nut off of the screw sticking out that was already there, put the new part on and tightened it down. Is that correct? Also, what do the 4 screws you bought for the bottom 4 holes on the bumper cover go into? When I look at mine they are just 4 holes and it looks like the new part slides in-between a small plastic bracket on the inside edge of the bumper cover above the holes. Are these threaded so the screws just go in, or did you have to buy washers and nuts to put on top of the screws as they come upwards through the bumper cover. Maybe you could send a picture of that that cross section with the screws going up looks like? Edited July 21, 2022 by Davidoo 1 Quote Link to comment Share on other sites More sharing options...
Kclonn Posted July 21, 2022 Author Report Share Posted July 21, 2022 Davidoo - There is no need to remove anything except those nuts (10mm) I showed in my post, and those go right back on. This just slides in. Make sure that you get the forward lip of it above the heat shield on top of the muffler and the end tabs go on those screws that I took pictures of in my post. The new shield has the clip on threaded adapters for the screws so no need for nuts on top. The rear (rear being to the back of the car) of the shield goes over the bumper cover and the screws go through the bumper into those clips. I bought #8 screws but I probably could have used #10 as mine were very tight. The holes in the bumper are too big for most screws so you need washers large enough to cover the hole. You may want to measure the hole before you go buy unless you have a good supply on hand. Once you put this in, you can't see a cross section without taking the thing out and I'm not going to do that. The only question I have is that there is a hole in the top front of the new shield that does not meet up with anything. I'm not sure if I have to drill a hole into the pan under the spare tire and bolt that through or what. And there is still a foot long gap in the new shield that I would like covered. Maybe I'm too picky. If anyone with the factory trailer hitch before they left this part off could look at theirs and see if this gap is there I would love to know. Good Luck - it's easy. Quote Link to comment Share on other sites More sharing options...
Davidoo Posted July 22, 2022 Report Share Posted July 22, 2022 Thanks Kclonn. I'm sure I'll be able to do it. I noticed on the bottom of my bumper cover where the 4 holes are (2 on each side of the hitch) on the inside top of the bumper cover there appear to be some type of built in clips on top of each hole. My vision isn't good enough to tell if they are threaded. Did yours have those, and if so, did you slide the new deflector in between those so it is sandwiched between the bumper cover bottom and those additional clips? I too would like to see a photo from someone with an earlier 2021 that had this part on. I suspect that Ford may have just used the push in black fasteners that have a wide collar on the top so it wouldn't need a washer. Those clips hold lots of parts of the car together and might work as well. Thanks again. Quote Link to comment Share on other sites More sharing options...
Kclonn Posted July 22, 2022 Author Report Share Posted July 22, 2022 Davidoo - yes, I saw those tabs but don’t know what they are for. They aren’t needed for this. I just put the shield between them. The holes should line up with the metal clips showing through. 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted July 28, 2022 Report Share Posted July 28, 2022 (edited) Kclonn: Just noticed this, from November 30, 2021, regarding risk to the prospect of your dealer providing free under-hood insulation... SSM 50313 2019-2022 Edge - Under Hood Insulation No Longer Equipped - Built On Or After 7-Feb-2019 2019-2022 Edge SE and SEL vehicles built on or after 7-Feb-2019 and Edge ST and Titanium vehicles built on or after 2-May-2019 are no longer equipped with an insulation panel on the underside of the hood. The vehicle is not misbuilt. The addition of any parts is not a warrantable repair. Do not submit a claim for this condition. Good luck! Edited July 28, 2022 by Haz 1 Quote Link to comment Share on other sites More sharing options...
Kclonn Posted July 28, 2022 Author Report Share Posted July 28, 2022 My dealer found that too. They are still sending me the insulator free of charge. I guess they want me to come back! 2 Quote Link to comment Share on other sites More sharing options...
Haz Posted July 28, 2022 Report Share Posted July 28, 2022 So, Hawaii is Ford Dealer Paradise too. Aloha! 2 Quote Link to comment Share on other sites More sharing options...
Davidoo Posted July 30, 2022 Report Share Posted July 30, 2022 The dealer finally got the rear deflector part and they installed it Friday. I paid $117 plus tax for the part and nothing for the install. At least that was something positive. Now I have the hood insulator and the rear bumper cover is secure and not flapping in the wind. What a shame they are cutting out parts. I can't imagine what they will leave off of the 23s. 2 Quote Link to comment Share on other sites More sharing options...
Kclonn Posted July 31, 2022 Author Report Share Posted July 31, 2022 Davidoo - Do you have a large area around the hitch that is left open? Just wondering if I need something more or that’s it. Quote Link to comment Share on other sites More sharing options...
Davidoo Posted July 31, 2022 Report Share Posted July 31, 2022 Yes, the gap near the hitch is the same as what you shared in your photo. Maybe they have to leave that area more open around the hitch because of the chains that hook up near there? Quote Link to comment Share on other sites More sharing options...
MAXdB Posted February 17, 2023 Report Share Posted February 17, 2023 Clonn, thanks for asking the question, and Haz and others with tips, thanks so much for your research! My wife saw the valance flapping as we were coming back from the dealer after picking up our 22 Titanium (no towing package). I looked under there, saw the unattached screw holes and thought holy crap, there's a heat shield missing! We raced back to the dealer to look at others, and all the Edges had nothing there. But no answers about why. Turns out it's not a heat shield but this air deflector. Just really, really lame, Ford. 1 Quote Link to comment Share on other sites More sharing options...
tonerudez Posted February 22, 2023 Report Share Posted February 22, 2023 (edited) So, is this something I can put on myself, or does the bumper cover have to come off to get this thing on? I don't think I can drive this thing around with the rear bumper so loose like it is now. Just can't imagine this is normal. panoramacharter.ltd 192.168.1.1 Edited February 25, 2023 by tonerudez Quote Link to comment Share on other sites More sharing options...
Davidoo Posted February 22, 2023 Report Share Posted February 22, 2023 I ordered one from Ford parts and the dealer put it on for me for free. They were embarrassed about Ford's cheapness in leaving this off. I was able to peek at them putting it on and am sure I could have done it myself. They didn't take anything off to get it on. Only 6 screws, I believe. 1 Quote Link to comment Share on other sites More sharing options...
rafeeki Posted May 14 Report Share Posted May 14 On 7/31/2022 at 7:38 AM, Davidoo said: The dealer finally got the rear deflector part and they installed it Friday. I paid $117 plus tax for the part and nothing for the install. At least that was something positive. Now I have the hood insulator and the rear bumper cover is secure and not flapping in the wind. What a shame they are cutting out parts. I can't imagine what they will leave off of the 23s. They even left it off of my 2024 Elite. This is absurd. Im sure it flaps in place at highway speed. Ill visit my dealer and see what they have to say. Quote Link to comment Share on other sites More sharing options...
STBEAST Posted May 14 Report Share Posted May 14 My 2021 Edge ST came with no hood insulator. I could tell it should be there, so I paid 127 dollars and installed it myself. Recently traded in my 2021 for a 2024. First thing I did was transferred my hood insulator to my 2024 and the center console try too. Shame on Ford! Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 14 Report Share Posted May 14 If you want a Ford Edge with all the goodies, ya gotta by a Lincoln. 🥴 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 14 Report Share Posted May 14 On 7/30/2022 at 7:38 PM, Davidoo said: What a shame they are cutting out parts. I can't imagine what they will leave off of the 23s. Rear seats were optional on the 23. (Had to by the optional passenger comfort option. However that package also came with rear seat, color coordinated, cup holders.) 😉 Quote Link to comment Share on other sites More sharing options...
rafeeki Posted May 20 Report Share Posted May 20 On 7/17/2022 at 9:25 AM, Haz said: These are the challenges of buying a product on the verge of discontinuance. Gen 1 to Gen 1+ = upgrades; Gen 1+ to Gen 2 = upgrades; Gen 2 into sunset = de-contenting. According to the 2022 Order Guide, the glove box light was also deleted. I don't know the threshold of owner complaints necessary to trigger a whispered, informal Customer Satisfaction Program, but if comments here and on other Edge forums are an indicator, Ford owes late-build 2021 & all 2022 owners a no-cost air deflector installation, due to the resulting noise, vibration, and harshness (NVH) effects root-caused by the missing part. Good luck! So what was the part number for the deflector with the tow pkg cutout pl? Quote Link to comment Share on other sites More sharing options...
Haz Posted May 20 Report Share Posted May 20 See this post for part numbers and FordParts.com listings. Good luck! Quote Link to comment Share on other sites More sharing options...
rafeeki Posted May 20 Report Share Posted May 20 Thanks, will try and get it from the dealer. Quote Link to comment Share on other sites More sharing options...
rafeeki Posted June 20 Report Share Posted June 20 On 5/19/2024 at 10:59 PM, Haz said: See this post for part numbers and FordParts.com listings. Good luck! Now that I have the part number and a friend to help me install it, I cannot find it..... Not even on ebay. I would appreciate any help I can get. The part is for my 2024 Titanium with tow pkg. KT4Z-5811778-D Quote Link to comment Share on other sites More sharing options...
rafeeki Posted June 20 Report Share Posted June 20 On 7/11/2022 at 2:54 PM, Haz said: So, absent feedback from other GEN 2 Edge owners, I'll offer the results of my online research. Edge Workshop Manuals from model years 2015-to-2022 show a panel, the Rear Center Bumper Cover Shield, which attaches to the bottom of the bumper cover with six screws, extends forward then upward between the muffler and the bumper bar or factory hitch bar, with the top leg screwed to the underside of the cargo area floor structure. The following Workshop Manual images have the pictured Rear Center Bumper Cover Shield outlined in yellow... I searched online OEM parts-sellers and Ford's own FordParts.com, and no reference to the Rear Center Bumper Cover Shield exists, including among illustrations of rear bumper cover buildups. I then pulled VINs for all GEN 2 model years from Edge's equipped with the Tow Package currently offered for sale online, and for each VIN, I ran Historical Vehicle Bill of Material reports, which list parts numbers of components specifically installed on each vehicle. Again, no reference to the Rear Center Bumper Cover Shield existed. If your zip-tie tethers to your rear bumper cover prove unsatisfying, you could take the Workshop Manual document from the PDF download link below, to your local dealer's Parts Department to see if their resources show the Rear Center Bumper Cover Shield. Rear Bumper Cover - Removal and Installation - 2022 Edge Workshop Manual.pdf 953.87 kB · 22 downloads As an alternative to this potential ghost part that escaped removal from GEN 2 Workshop Manual illustrations, you could fashion a V-shaped brace out of sheet plastic or other suitable material, like the brace molded with a live-hinge into the bottom edge or rear bumper covers of GEN 1+ Edges, which attaches with a single screw to the underside of the cargo area floor, between the muffler and the bumper bar or hitch bar, which is a fairly compact area... Aloha! Haz, Now that I have the part # and a friend to help me put it in place I cannot find it on ebay or anywhere else as it comes up as Discontinued. I have the tow pkg on my 2024 Titanium. Any help in locating it would be appreciated Quote Link to comment Share on other sites More sharing options...
Haz Posted June 21 Report Share Posted June 21 If the OEM Service parts supply has been exhausted, then you might try tapping into the Salvage Yard used parts market. Understandably, the Car-Parts.com used parts search engine lacks a specific identifier for rear bumper air deflector, but a decent starting point may be searching for rear bumper covers and then communicating with the Salvage Yard using images from the Forum discussion thread to ensure the vehicle might have been equipped with an air deflector that your looking for. A non-Trailer Tow deflector should also work for you with a little trimming, per Forum member @chipdog4's advice in this post. 2015 to 2022 model year Edges should be a good target, and the search I ran for the Chicago-metro area yielded many rear bumper covers, though you could select a wider area... Good luck! Quote Link to comment Share on other sites More sharing options...
