Perspective Posted June 24, 2022 Report Share Posted June 24, 2022 (edited) 2015 Ford Edge 2.0 eco-boost. Hello, today I was driving my edge with a full tank of gas and was cruising along at 67 mph and my wife reminded me it was a 70mph zone. I tried to accelerate and it down shifted but wouldn't speed up. I figured out that if I accelerated slow I could get it to 70. I decided to stop and turn off the car and restart which fixed it. After driving about 20 minutes at speed it did it again. After restarting again it ran fine but the engine light came on. It seems the transmission is working fine but there isn't any power until I restart. When it starts to have the problem it won't accelerate at any speed. The auto store reader could only get a generic code. Anybody got any ideas. I'm thinking maybe MAF. Feels like a fuel/air issue to me. Edited June 24, 2022 by Perspective Quote Link to comment Share on other sites More sharing options...
akirby Posted June 25, 2022 Report Share Posted June 25, 2022 Guess would be throttle body but you need the codes to be sure. Quote Link to comment Share on other sites More sharing options...
Perspective Posted June 25, 2022 Author Report Share Posted June 25, 2022 (edited) Thank you! Ended up getting P1016 wastegate Control Pressure Higher Than Expected with a recommendation to replace the turbocharger wastegate solenoid. Finished this afternoon and it seemed to fix the problem. Last night it did it again but I was able to prevent by not maintaining speed. Seems to only happen when I maintain a higher speed for a while. Edited June 26, 2022 by Perspective 1 Quote Link to comment Share on other sites More sharing options...
Perspective Posted June 26, 2022 Author Report Share Posted June 26, 2022 So I did find a very clear vacuum leak but need help identifying the part. It is the vacuum line that goes to the left and circled in the below photo. Does anyone have a good diagram they can look up the part on? Not visible in the photo but it is cracked on the underside and hisses really bad. Not sure if this would affect the turbo but I figured it probably isn't good anyway. Quote Link to comment Share on other sites More sharing options...
Perspective Posted June 28, 2022 Author Report Share Posted June 28, 2022 (edited) PROBLEM SOLVED: So this was definitely the problem. I went to my local Ford dealership and provided the part number but you had to buy the entire vacuum hose system. He told me he didn't even want to tel me the price. I went to my local parts store and just purchased a length of rubber vacuum hose and installed. Drove it for a while at steady speed and no issues. I believe the leak was preventing enough pressure to overcome the turbo pressure on the wastegate that would build up at steady speed. When driving around town there was enough adjusting the throttle to not build up pressure. Edited December 5, 2022 by 1004ron No need to quote your own posts 3 Quote Link to comment Share on other sites More sharing options...
Edward Posted December 5, 2022 Report Share Posted December 5, 2022 (edited) Loss of Power while driving/car goes into Limp Home (Ford term) mode: (see take aways at bottom of response for complete list of parts that need to be replaced to fix P1016 error code) After owning my 2015 Edge SEL for over 7 years (original owner) out of the blue I experienced a substantial loss of power (LoP)/Limp Home mode while highway driving w/o any warning lights on the dashboard. I pulled over to a safe location and listened to the motor for any tell tale indications of what might be wrong but the motor sounded fine. Turned it off, waited ~ 1 minute, restarted and all was well. Got back on the highway with good acceleration and drove home. Please note, this was the very first time my Edge had been anything other than perfect as far as operation and transport and assumed this was a one time “who knows” event and didn’t give it further thought. Unfortunately, over the next 2 months it started to happen more and more frequently so I started to look around the internet to find what the cause(s) might be. Turns out quite a few other owners had experienced similar symptoms followed by unfulfilling dealership repair shop visits e.g. Technicians would say no error codes/trouble lights were found and they could not replicate the LoP during their analysis but the theories offered were many and varied e.g. spark plugs fouled, fuel lines clogged, fuel pump malfunction, catalytic converter, air filters, fuel filters, etc. At this point I was quite troubled and didn’t want to get into some endless “visits to the Dealership repair shop” w/o any success but costing hundreds of dollars for each visit. Being all the technician stories included “lack of OBD2 error codes” being found I decided to buy one to monitor the motor real time and see if it would be helpful in discovering what was wrong. I bought the lower end version of “FIXD” OBD2 Diagnostic Trouble Code (DTC) Decoder for ~$39 and it was delivered to my house the next day. Installation was simply to plug into the receptacle jack located under driver side dashboard on cars made after 1995, down load the FIXD App and then Blue Tooth connect to my Android based cell phone. JACKPOT. Within 1 day of driving while being monitored real time by FIXD my cell phone reported error code P1016 “Wastegate Regulating Valve had experienced overpressure to the turbo charger”. FIXD not only decoded what the code meant it also identified 3 specific parts that if malfunctioning would cause the error. Armed with this information, I went to the local Ford Dealership with printouts of what FIXD had provided and asked them to repair. We agreed they should do a diagnosis with their more sophisticated error machine to confirm my findings and their machine gave the same findings. They installed the Wastegate Regulating Valve and the two tubes identified below. I picked car up next day and worked fine ever since. Key Take Aways: .Buy an OBD2 real time monitoring device to reduce stress/uncertainty and put ourselves on equal information footing with the dealership technician .Suggest replacing all parts that the OBD2 identifies to avoid multiple visits to the shop. Parts for replacement are: .Wastegate Regulating Valve (WRV) .Control tube btwn the WRV & Wastegate Actuator .Tube btwn vacuum reservoir & WRV .2015 Ford Edge SEL is an excellent car and I would buy same car again Edited December 5, 2022 by 1004ron No need for excessive text size Quote Link to comment Share on other sites More sharing options...
