Hood Latch Replacement
SpykeYs
Hi !
I need to replace my hood latch on a Ford Edge 2016. I have the part with me.. FT4Z-16700-A...
Is it only a matter of removing the two 10mm bolts, removing the sensor cable and cable ? Do I need to remove any plastic cover or anything else ?
Thanks
Below are PDF download links to relevant sections of the 2016 Edge Workshop Manual...
Bumper Cover and Active Grille Shutter procedures are included, just in case they prove to be necessary for you.
Good luck!
Hood Latch - Removal and Installation - 2016 Edge Workshop Manual.pdf
Front Bumper Cover - Removal and Installation - 2016 Edge Workshop Manual.pdf
Active Grille Shutter - Remaoval and Installation - 2016 Edge Workshop Manual.pdf
Good luck!
Thank you so much! I really do appreciate it.
  • 5 months later...
