1004ron Posted June 7, 2022 Report Share Posted June 7, 2022 This morning was the first and only fault ever encountered in my 5+ years of ownership. Got in, foot on brake, in park, and hit the start/Ign button, all dashboard lights came on and the left side of the dashboard scrolled just about every warning, but no crank. Battery is less than a year old, and voltage measured at 12.5v Removed + terminal for a few seconds, put it back and still the same failed to crank. Replaced the batteries in both key fobs, and tried one of the fobs in the center console in the location used when the fob battery is low, and still same no crank. Pulled the battery terminal for about 3 minutes, reconnected and it cranked at usual speed and started. Drove 38 miles to work, parked, tried again and its started perfectly. Google search came up with loads, but most were gibberish. Anyone encountered this - any suggestions on what to check. Quote Link to comment Share on other sites More sharing options...
ben senise Posted June 7, 2022 Report Share Posted June 7, 2022 (edited) a couple of points that may or may not be related; 1- measured voltage is irrelevant. it can still show 12+v and not have enough juice to crank. i had that happen and the cause was a cracked cell. still showed good voltage but not enough current would flow. 2- the batteries in the key fobs are for the lock/unlock and engine start transmit function. the anti-theft chip in the key is passive (RFID). it works without a battery and you can test it. the fact that you removed the terminal and replaced it could mean that you may have dislodged corrosion on the battery post. do you have a battery post cleaner brush? google it if you're not familiar. that would be my first step. Edited June 7, 2022 by ben senise 2 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted June 7, 2022 Report Share Posted June 7, 2022 As Ben said, also if it happens again, try wiggling the gearshift (possible interlock hickup). 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 7, 2022 Report Share Posted June 7, 2022 I’ve had the same pinball machine effect occur in the gauge clusters of our 2012 MKX and our 2015 MKX. The 2012 slow-cranked and started, but transitioned to no-crank a few days later. Its seven-year-old original battery tested bad. The 2015 no-cranked with a 3-month-old battery in place. Battery tested bad and was replaced under warranty. Many gauge cluster warnings are low-voltage triggered, and most codes will clear when subsequent key cycles serve up normal voltage. Have the battery tested -- probably a bad cell or bad cells. Below is a PDF download link to TSB 17-2219, relating to the park-detect switch failure which did occur in our 2012, but its symptom was limited to a "Shift To Park" gauge cluster message and it did not present any no-crank condition. Good luck! TSB 17-2219 - 2011-2017 Edge, 2011-2015 MKX, & Other Models - 'Shift To Park' Message, Park-Detect Switch .pdf 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 7, 2022 Author Report Share Posted June 7, 2022 Thanks for all the comments and suggestions. When I got home I connected my battery tester and it shows the same health as it did when I bought it from Costco in November 2021. When I installed the new battery I replaced the negative connector and added the felt pads on the terminals. Both terminals clean and secure. Started a few times today with no sign of any issues. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 8, 2022 Report Share Posted June 8, 2022 Check what codes you get with ForScan. Though you will probably have many voltage/connection related due to the battery disconnection/reconnection, but some might give an indication. I say ForScan as it can read all modules, not just the PCM (you probably know that). 2 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 8, 2022 Author Report Share Posted June 8, 2022 It happened again this morning. Using Forscan is a good idea, but didn't have time to get out my Windows laptop, renew the license and hook it up - I'll do that when I get home later today and have it ready if it fails to start tomorrow (not going to work tomorrow, so will have time for more interrogation). I hooked up my OBDLink MX+ but the OBDLink app wouldn't connect, even though the iPhone's bluetooth showed connected. I then disconnected the battery, and while disconnected ran my tester again and it showed good health. Reconnected and it started up normally - good crank speed and quick ignition - thereafter the OBDLink app did connect and showed no errors, which can be expected as they would have been cleared with the battery disconnected, but odd that it couldn't communicate with the vehicle earlier. Warning notices displayed in the left of the dashboard: Steering Assist Fault Service Required LOW Engine Oil Pressure Engine Coolant Over Temperature Blindspot System Fault - OFF Cross Traffic System Fault AWD Malfunction Service Required See Manual Odd thing is the mileage showed _ _ _ _ _ _ _ It could be an intermittent fault in the relatively new battery, or an electrical connection on the vehicle - not always the easiest to diagnose, but I'll keep at it with the help offered here, thanks. When I arrived at work, a little late, I tried starting with the gear selector NOT in P or N, and of course it doesn't start, and doesn't light-up all the errors. 1 Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 8, 2022 Report Share Posted June 8, 2022 31 minutes ago, 1004ron said: Using Forscan is a good idea, but didn't have time to get out my Windows laptop, renew the license and hook it up - I'll do that when I get home later today and have it ready if it fails to start tomorrow (not going to work tomorrow, so will have time for more interrogation). To read codes, ForScan doesn't need a license. License is needed for ABD configurations. OBDlink app, did you download the "Enhanced" DTCs for your model year? If not, the app will only read the regular OBD II codes. As for your mileage showing _ _ _ _ _ _ _, I have no previous experience with it, just guessing that since the mileage is stored in the IPC itself, could it be an indication of a failing cluster? 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 8, 2022 Author Report Share Posted June 8, 2022 (edited) Thanks @omar302 I checked and confirmed the OBDLink app has the enhanced OEM Add-Ons and while I was checking for that I updated the device firmware, and still no codes presented. I then used Forscan Lite and it showed loads of communication fault codes - see attached text file. Won't trust the OBDLink app for this again. Soon after starting the engine the charging voltage was around 14.5v and after a while it settled at 13.6v - not sure what's going on with that, but will use the OBDLink dashboard to monitor on the way home. DTC_2022-06-08_110115.txt Info_2022-06-08_105957.txt Edited June 8, 2022 by 1004ron 1 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 8, 2022 Report Share Posted June 8, 2022 Beginning with the odd symptom -- explanation of the 'all-dashes odometer' & Pinpoint Test G, from the 2017 Edge Workshop Manual... Good luck! Symptom: The Odometer Is Inoperative Normal Operation and Fault Conditions If the odometer count message is missing from the PCM through the GWM for 5 seconds or longer, the IPC defaults the odometer display to all dashes (------). If the odometer count message is deemed invalid by the IPC , the IPC defaults the odometer display to all dashes (------). If the NVM becomes corrupted or if any NVM failure occurs, odometer displays ERROR. Possible Sources Communication concern GWM concern PCM concern IPC PINPOINT TEST G: THE ODOMETER IS INOPERATIVE G1 CHECK FOR CORRUPTED NON-VOLATILE MEMORY (NVM) Ignition ON. Observe the message center display area. Does the odometer display ERROR? Yes VIN required to access Guided Routine (IPC) No GO to G2 G2 PERFORM THE IPC (INSTRUMENT PANEL CLUSTER) SELF-TEST Using a diagnostic scan tool, perform the IPC self-test. Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to DTC Chart: IPC in this section. No GO to G3 G3 CHECK THE GWM (GATEWAY MODULE A) DIAGNOSTIC TROUBLE CODES (DTCS) Using a diagnostic scan tool, check the GWM Continuous Memory Diagnostic Trouble Codes (DTCs). Are any Diagnostic Trouble Codes (DTCs) recorded? Yes REFER to: Communications Network (418-00 Module Communications Network, Diagnosis and Testing). No DIAGNOSE all PCM Diagnostic Trouble Codes (DTCs). Refer to the appropriate section in Group 303 for the procedure. 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted June 9, 2022 Report Share Posted June 9, 2022 I'm sure you double checked the wiring on the terminals/ grounds etc? Try leaving your positive battery cable unplugged for 15 min. I believe that it will reset the BCM. If that doesn't work try leaving it unplugged for over night. Clear the codes after your initial scan. Shut down and restart and rescan you should see that the DTC's have been cleared. Take a look at the BMS in FORScan, did you change it for your upgraded size? IIRC I believe that you did that in one of your previous post. HTH Quote Link to comment Share on other sites More sharing options...
omar302 Posted June 9, 2022 Report Share Posted June 9, 2022 @1004ron Just guessing here, but one code stood out for me as it pretrains to the ignition switch and at a mileage about 178 KM before current reading. Check the Event Time, do you think it coincides with when the 1st fault came or when you disconnected the battery? On another note, having the OBDLink MX+, due keep it plugged in? If yes, since when? Reason I am asking is because I a strange issue come up some time ago (link to Post), though I did not get any dash lights, the solution was to disconnect the battery. It happened twice and in both cases I remember having the OBDLink MX plugged in for a while. Couldn't get a diagnosis on it and since then I never keep the OBDLink plugged in and it hasn't re-appeared. Quote Code: U300A - Ignition Switch Additional Fault Symptom: - Signal Invalid Status: - Previously Set DTC - Not Present at Time of Request - Malfunction Indicator Lamp is Off for this DTC Module: Antilock braking system Freeze Frame #1: -EVENT_TIME: 170563383 s (Tue Jun 7 06:21:55 2022) - Event time -TOTAL_DISTANCE: 128360 km - Total Distance -MODULE_VOLTAGE: 11.8 V - Control Module Voltage -POWER_MODE: Crank - Power Mode Status -RSC: Inactive - RSC -BTC: Inactive - BTC ===END ABS DTC=== 4 Quote Link to comment Share on other sites More sharing options...
Haz Posted June 9, 2022 Report Share Posted June 9, 2022 I'd never expect it, but do you park outside? Good luck! Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 9, 2022 Author Report Share Posted June 9, 2022 Always parked inside my attached garage, unless its at work in the open parking lot. This morning it started without a problem, so can't do any further diagnostics until it occurs again. 1 Quote Link to comment Share on other sites More sharing options...
onyxbfly Posted June 10, 2022 Report Share Posted June 10, 2022 Intermittent electrical issues can be notoriously frustrating at times. As much as we would all love for you to get to the bottom line with this! I'm hoping this particular gremlin doesn't rare its head again! I'm sure you will sort it out if it eventually returns. 1 Quote Link to comment Share on other sites More sharing options...
1004ron Posted June 21, 2022 Author Report Share Posted June 21, 2022 (edited) Update: On 9 June I lifted all the relays in the engine compartment fuse box and reseated them and since then its never misbehaved. Speculation, but maybe a little oxidation on one of the terminals related to the data bus ? Fingers crossed that its resolved. I bought a hard copy wiring diagram service manual, not as nice as the color schematics @Haz posts, but it should help if I need to do any fault finding in the future. Edited June 21, 2022 by 1004ron 2 1 Quote Link to comment Share on other sites More sharing options...
Torr22 Posted October 27, 2023 Report Share Posted October 27, 2023 My edge is doing this today. Does anyone know what the fix is? 2019 Ford Edge SEL AWD Quote Link to comment Share on other sites More sharing options...
Haz Posted October 28, 2023 Report Share Posted October 28, 2023 Welcome to the Forum, Tor22 ! On 6/7/2022 at 4:29 PM, Haz said: Many gauge cluster warnings are low-voltage triggered, and most codes will clear when subsequent key cycles serve up normal voltage. Have the battery tested -- probably a bad cell or bad cells. Good luck! Quote Link to comment Share on other sites More sharing options...
1004ron Posted October 28, 2023 Author Report Share Posted October 28, 2023 On 10/27/2023 at 12:15 PM, Torr22 said: My edge is doing this today. Does anyone know what the fix is? 2019 Ford Edge SEL AWD Have you considered any of the suggestions in this thread? 1 Quote Link to comment Share on other sites More sharing options...
jinxbee Posted April 10, 2024 Report Share Posted April 10, 2024 So my wife's 2019 Edge just started doing this a few days ago. I took it to my local Ford Dealership, they replaced the battery and a wire connector under the dash. It starts now,but did it one more time this morning. It feels like a ghost in the machine. Quote Link to comment Share on other sites More sharing options...
1004ron Posted April 10, 2024 Author Report Share Posted April 10, 2024 Mine has been faultless since June 2022. Quote Link to comment Share on other sites More sharing options...
