Herbaldew Posted May 26, 2022 Report Share Posted May 26, 2022 Hi, I recently purchased a 2018 Edge. I more recently noticed that the toggle on the end of the wiper switch does not turn on the rear wiper. However, the rear wiper does work when the switch is pushed for a rear window wash, so not a fuse or motor issue. My guess is the switch is bad. I can't find a video on removing the switch on this year, just older Edge's and this is definitely different. Can anyone point me to a source with information on removing it? Thanks Quote Link to comment Share on other sites More sharing options...
CARR142 Posted May 26, 2022 Report Share Posted May 26, 2022 Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 27, 2022 Report Share Posted May 27, 2022 Attached are the related service procedures. It's similar to the Explorer as posted by @CARR142 Steering Column Control Switch.pdf Steering Column Shrouds.pdf Steering Column Multifunction Switch LH.pdf Quote Link to comment Share on other sites More sharing options...
Herbaldew Posted June 2, 2022 Author Report Share Posted June 2, 2022 Thanks guys! I had viewed that YT video but hadn't taken a good look at my wife's Edge at that time. After watching it again, and looking at her Edge it was close enough. On her Edge it was a simple as removing two screws on the bottom shroud, prying the two halves of the shroud apart and removing the two screws holding the switch in place. Ten minutes or so and job done. Thanks again 1 Quote Link to comment Share on other sites More sharing options...
