Sharry Posted May 15, 2022 Report Share Posted May 15, 2022 I have been trying to find Ford Sync Navigation SD Card for middle east of Saudi arabia but I just could not. I bought a 2 year old user Ford Edge from the dealership and the Navigation SD card was missig. The dealership is not helpful at all and I tried to reach the distributor but they said that you would have to change the entire Sync system just to get the maps working I checked my Sync device and all it says is "Insert Navigation SD Card" Can anyone help me find the Navigation SD card or its image from the internet or the Ford itself? Quote Link to comment Share on other sites More sharing options...
Will2U Posted May 15, 2022 Report Share Posted May 15, 2022 If you haven't done so already, you might want to check in www.fordsyncforum.com. It is all about Sync. Perhaps someone there can give you a lead. Quote Link to comment Share on other sites More sharing options...
ben senise Posted May 15, 2022 Report Share Posted May 15, 2022 your edge should be able to run android auto off of an android phone plugged into the USB port. I'm not familiar with Apple Car Play but i would guess it's similar. Google maps is infinitely better than the built-in navigation. Personally i would forget the Sync Navigation and go with a phone if possible. Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 15, 2022 Report Share Posted May 15, 2022 2 hours ago, Sharry said: I have been trying to find Ford Sync Navigation SD Card for middle east of Saudi arabia but I just could not. I bought a 2 year old user Ford Edge from the dealership and the Navigation SD card was missig. The dealership is not helpful at all and I tried to reach the distributor but they said that you would have to change the entire Sync system just to get the maps working I checked my Sync device and all it says is "Insert Navigation SD Card" Can anyone help me find the Navigation SD card or its image from the internet or the Ford itself? What model is your Edge? There is no Navigation SD Card for the Middle East. Quote Link to comment Share on other sites More sharing options...
Sharry Posted May 15, 2022 Author Report Share Posted May 15, 2022 Hello Omar and thanks for your reply. It's a 2013 Ford Edge. I moved here to Saudi Arabia four years back and bought this beautiful car. However, unfortunately, there are no maps or map SD card in it. The GPS in it works as it tells the exact coordinates, so I think if I am able to get the maps for my region then the Navigation will work as well. I check the dealership and they just said that you have to change the whole Sync panel to get the map working but I don't think it's necessary as I just need the Map SD card. Please let me know if there is a solution to this. Regards Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 15, 2022 Report Share Posted May 15, 2022 There is no SD Card maps for the Middle East for the original MyFord Touch system (Sync 2). The solution is to change it, hack it, or install an aftermarket add-on. Quote Link to comment Share on other sites More sharing options...
Sharry Posted May 15, 2022 Author Report Share Posted May 15, 2022 @omar302 Can you please guide me to the "hack-it" or "after-market" solutions? Is there a guide or blog somewhere for "hack/fix-it" kind of solution. Your support would be highly appreciated. Regards Quote Link to comment Share on other sites More sharing options...
1004ron Posted May 15, 2022 Report Share Posted May 15, 2022 I used the resource found in the below thread: You should contact Cyanlabs for their advice on which files to download. https://cyanlabs.net/applications/syn3-updater/ 1 Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted May 15, 2022 Report Share Posted May 15, 2022 The 2013 Edge used the map database from HERE maps. They are one of the largest map suppliers in the world and had definitely mapped Arabia. However, I don't think they made maps for the Ford Sync system, for other than the North American market. (Ford specified the format and Here supplied). You could contact them directly and ask. (Perhaps they might know of a foreign supplier that has)? The contact links is: https://ford.navigation.com/cms/page.ContactUs/en_US/FordNA/USD Quote Link to comment Share on other sites More sharing options...
omar302 Posted May 16, 2022 Report Share Posted May 16, 2022 15 hours ago, Sharry said: @omar302 Can you please guide me to the "hack-it" or "after-market" solutions? Is there a guide or blog somewhere for "hack/fix-it" kind of solution. Your support would be highly appreciated. Regards Check this thread on XDA, specifically the last 10 pages or so. 1 Quote Link to comment Share on other sites More sharing options...
