Bluetooth?
Does the MKX come with Bluetooth as an available option? I was reading about the new SYNC system in fall models. Does anyone know if that will be available as a retrofit in '07 models? When are the "fall"models typically available? One last question: is the DVD nav system also voice-activated? Thanks. This is a great forum.
I don't know about the MKX, but I believe the Bluetooth is a dealer added option on the Edge. I hope the '07 cars are able to be retro-fit for Sync. I believe you can start ordering in Aug. for the '08 models normally, but with such a late delivery on the '07's maybe they all should called '08's :shades: . The fall models usually hit the dealers Sept. or early October. The nav system I believe is voice activated.
The mobile ease bluetooth option can be added as an accessory to the Edge. You can find it at this link:
http://www.fordaccessoriesstore.com/fas/b2c/catalog.asp under interior > electronics > Mobile ease
and cheaper at this link:
http://partscheap.com/edge07.htm
However, I too was wondering if they would offer Sync as an add on later in the year. I have e-mailed Ford and asked but have received nothing back yet. Hope this helps. Yelnef
Do you think the Mobile-ease can also be added to the Lincoln MKX?
