IcyFridge Posted April 8, 2022 Report Share Posted April 8, 2022 The parking/turn bulbs on my 2019 SE are PSY24W, and I’m having a tough time finding a LED alternative. I know PSX24W are easily swapped out, but I can’t find any alternatives for the “Y” variant. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 9, 2022 Report Share Posted April 9, 2022 https://www.amazon.com/Ruiandsion-PSY24W-Yellow-Chipsets-Replacement/dp/B08DHT5WVT 1 Quote Link to comment Share on other sites More sharing options...
IcyFridge Posted April 9, 2022 Author Report Share Posted April 9, 2022 7 hours ago, enigma-2 said: https://www.amazon.com/Ruiandsion-PSY24W-Yellow-Chipsets-Replacement/dp/B08DHT5WVT That’s actually a PSX24W or 5202 bulb. I haven’t seen a single PSY24W online. All the pictures I see are of bulbs with a plastic base, but mine don’t have a base. I pulled and verified this. Bulb indeed says Psy24w on it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted April 9, 2022 Report Share Posted April 9, 2022 It's labeled as a PSY24W and appears somewhat identical to a PSX24W. https://www.amazon.com/dp/B09N8VDMJ8/ref=cm_sw_r_awdo_P2PNFSSXZFZB82X02P01 This is the turn signal bulb RockAuto is showing to fit your 2019. https://www.rockauto.com/en/catalog/ford,2019,edge,2.7l+v6+turbocharged,3443235,electrical-bulb+&+socket,turn+signal+lamp+bulb,13675 Looking in the owners manual for the 2019, the front directional bulb is a LED identified a WY21W. Can you post a picture of the bulb? To be certain, you may need to check with your dealer to get the right bulb. I know that my MKX specified specific bulbs and the dealer had to specifically order the bulb. (Of course they were 10x more expensive than the equivalent than aftermarket). 1 Quote Link to comment Share on other sites More sharing options...
WWWPerfA_ZN0W Posted April 14, 2022 Report Share Posted April 14, 2022 an alternative look https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313&_nkw=PSY24W&_sacat=0 1 Quote Link to comment Share on other sites More sharing options...
IcyFridge Posted August 30, 2022 Author Report Share Posted August 30, 2022 The PSX have a plastic base. On the 2019, there's a plastic base that screws out of the headlight and then the glass bulb comes out of it. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 2, 2022 Report Share Posted September 2, 2022 How about these? Alla Lighting PG20/4 Base 12188NAC1 PSY24W LED Bulbs Car Front Turn Signal Lights Bulbs Replacement, 6500K Xenon White https://a.co/d/6O5RW3l Quote Link to comment Share on other sites More sharing options...
IcyFridge Posted September 4, 2022 Author Report Share Posted September 4, 2022 On 9/1/2022 at 9:28 PM, enigma-2 said: How about these? Alla Lighting PG20/4 Base 12188NAC1 PSY24W LED Bulbs Car Front Turn Signal Lights Bulbs Replacement, 6500K Xenon White https://a.co/d/6O5RW3l Those still have a plastic base on them. I need to snap a pic and show you what I’ve got. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 4, 2022 Report Share Posted September 4, 2022 This one? Philips 12071B2 Light Bulbs Glass Base WY21W Pack of 2 in Blister Pack https://a.co/d/7brOrGe Quote Link to comment Share on other sites More sharing options...
IcyFridge Posted September 27, 2022 Author Report Share Posted September 27, 2022 On 9/4/2022 at 7:18 PM, enigma-2 said: This one? Philips 12071B2 Light Bulbs Glass Base WY21W Pack of 2 in Blister Pack https://a.co/d/7brOrGe Yep. Looks like those! But they're labeled PSy24W on the headlight cap. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 27, 2022 Report Share Posted September 27, 2022 Listed as a WY21W in the owners manual. ...? Quote Link to comment Share on other sites More sharing options...
IcyFridge Posted September 27, 2022 Author Report Share Posted September 27, 2022 23 minutes ago, enigma-2 said: Listed as a WY21W in the owners manual. ...? Egads, you are right. The headlamp housing says otherwise. I can't find any identifying marks on the bulbs themselves. When I have some time, I'll pull a bulb and compare with WY21W pictures online. Quote Link to comment Share on other sites More sharing options...
enigma-2 Posted September 27, 2022 Report Share Posted September 27, 2022 LED equiv? Alla Lighting Super Bright T20 7440 7443 LED Turn Signal Light Bulbs 7444NA 7441, Amber Yellow W3X16q Wedge Blinker Lamps, High Power 2835-SMD for Cars Trucks Lamps Replacement https://a.co/d/cYUteaN Quote Link to comment Share on other sites More sharing options...
